-   -   replacing window guide, what is the tape .. (http://forums.pelicanparts.com/porsche-911-technical-forum/457115-replacing-window-guide-what-tape.html)
crustychief 02-13-2009 12:07 PM
That is on the top outside of the door and rolls down under the slot seal? Is it just really thick vinyl tape or something that I can get at a autobody supply shop, ( or Vons?). I would like to replace mine while I am in there.
crustychief 02-13-2009 02:41 PM
O.K since nobody knows, I will just clean up what I have and put some RTV on the cracked spots.
teenerted1 02-13-2009 02:48 PM
i cant tell by your description what you are refering too....that could be why no responses.
photo would help
is it a seal? did you do a search?
crustychief 02-13-2009 03:22 PM
I searched. it is just tape on the outside of the door, it goes under the metal strip with the squeegee on it, I assume it is for added protection from the weather. I used some RTV and a lot of love, so I think it will be fine. I will post pics in a different thread since I documented the replacement of the window guide, and slot seal.
Cooper911SC 02-13-2009 03:42 PM
Hi Crusty,
I know what you are talking about. Not sure exactly what it is...however, it looks an awful lot like the 8mil thick (.008) clear bra material that I install.
Like you described, kind of a thick tape that the aluminum trim presses down over. I'll try looking in PET to see if they actually list a part #.
It seems like just an addditional seal or buffer to help the trim keep from moving around/vibrating.
Cooper
pozee 02-14-2009 02:19 PM
Look at this thread.
Is that what you're asking about?
http://forums.pelicanparts.com/porsche-911-technical-forum/446193-door-belt-moulding-tape.html?highlight=fender+tape
group911@aol.co 02-14-2009 02:34 PM
I've used a good quality electrical tape for years and it works fine.
