-   -   Relay part number (http://forums.pelicanparts.com/porsche-911-technical-forum/4574-relay-part-number.html)
rstoll 06-03-2001 04:54 PM
Relay part number
Anyone know the part number for relay under the passenger seat 1983 SC?
Robert Stoll
83 SC
83 944
andyjboy 06-04-2001 01:36 AM
Robert - what electrical system is it part of?
Andy Boyle(UK)
'69 911E
rstoll 06-04-2001 04:29 AM
It is located next to the computer under passenger seat and I think it runs the frequency valve. I have had intermittent trouble on cold starts. When the problem arises I can't here the frequency valve running. I took the relay out yesterday, and even though the coil in the relay was good it would not close under 12 volts. After a few trys and a little tapping on it, it started to work again.
Robert Stoll
83 SC
83 944
Rod Walter 06-04-2001 06:55 AM
Robert, the only relay that I can find in the parts & technical reference catalog that might be a candidate is described as the acceleration enrichment relay with part number 911 617 131 01. Unfortunately, its location isn't given but it does connect using eight pins arranged in a circle, so if this isn't the arrangement on yours then this is not the right one. It isn't a red or black standard relay is it?
Rod Walter
'88 911 coupe
rstoll 06-04-2001 07:11 AM
No Rod, this one has 5 or 6 spades on it and is a square aluminum colored relay. Must be an uncommon relay. Pelican doesnt list it either.
Robert Stoll
83 SC
83 944
Doug Zielke 06-04-2001 03:21 PM
Robert,
This is the infamous o2 sensor relay (as recently discussed by Mr. Walker, ie: "your car will run like crap without it").
The part number is 821 951 253
BTW...John W is a 911-genius! I pulled the relay as an experiment, and just as he said, the car ran like crap! I'm putting a spare in the toolkit this week.
Doug
'81 SC Coupe (aka: "Blue Bomber")
Canada West Region PCA
members.home.net/zielke/911SC.htm
[This message has been edited by Doug Zielke (edited 06-04-2001).]
WB3 02-24-2004 04:02 PM
For such a small part it sure caused me enough headaches! And it really wasn't the relay that was faulty. More like the wrench (me) and a bad luggage comp switch that shorted and blew fuses. And be aware as I learned from JW (who was one of the kind people to help me), that the 02 relay is wired into the interior light, clock, glove comp light, and luggage compartment light circuit. If that fuse is blown, as mine was, the 02 relay will not get power. And it WILL run like @%$&! Why they wired that relay into that circuit I don't know. Those switches in the doors and to a lesser degree the luggage compartment (unless you're a Targa owner like myself) take a beating from repeated use. And I guess they just short out like mine did. Now I can watch TV instead of climbing over the engine at midnight looking for the problem...in the rain. Eventhough the relay was ok, I'm still gonna lay down the bucks and get a spare. It causes multiple problems and grey hairs if it ain't workin.
Thanks all!
And thanks to Pelican for sponsoring this forum!
