-   -   RSR Trailing Arms (http://forums.pelicanparts.com/porsche-911-technical-forum/457446-rsr-trailing-arms.html)
chris_seven 02-15-2009 08:41 AM
RSR Trailing Arms
I have a Project that needs some 'short' RSR Trailing Arms, which are either impossible to find or cost a huge amount of cash.
I have been told, but am not sure, that they are the same length as the early SWB trailing arms.
If this is true it should be possible to make up a jig and shorten some LWB arms and add the caliper mounting brackets.
I am sure that there are probably some other changes and if any one has a sketch/dimensions that they would share I would be grateful.
Larry_Ratcliff 02-15-2009 10:23 AM
I believe that 930 trailing arms are the same as the RSR arms. They seem to come up for sale every couple of months.
Highfield 02-15-2009 10:43 AM
Chris
I have a contact who has jigs and specifically takes stock steel arms and shortens and strengthens them to RSR arms.
PM if you need details - he is in Droitwich, Worcestershire, UK.
Ian
chris_seven 02-16-2009 12:04 AM
Larry,
Thanks but the 3.3 Turbo has aluminium trailing arms which are not correct for an RSR but would fit and are relatively cost effective
Ian,
There are a pair advertised on eBay (UK) at the moment from Bromsgrove and I would guess that these are from Ben.
Unfortunately £3000 ($4500) is outside my budget and I need to find a more cost effective solution.
Thanks anyway.
JohnJL 02-16-2009 12:15 AM
Randy has a set of 930s for sale.
Highfield 02-16-2009 05:47 AM
Chris
Ben has lots of NOS and this could be some.
He also takes standard steel arms and converts them in a jig he has.
PM me and I can send his details.
Ian
Bill Verburg 02-16-2009 05:51 AM
Though the turbo arms are shorter they also increase the rear track width
