-   -   Removing rear badge emblem? (http://forums.pelicanparts.com/porsche-911-technical-forum/457470-removing-rear-badge-emblem.html)
Chris84Cab 02-15-2009 10:12 AM
Does anyone know the best way to remove the rear badge emblem with the adhesive backing? I need to replace mine and I don't want to damage the paint.
the 02-15-2009 10:34 AM
Heat it up with a hair drier and it'll pull right off. You can saw it off with some strong dental floss if needed.
Chris84Cab 02-15-2009 11:10 AM
Great idea... never would have thought of that.
m110 02-15-2009 01:16 PM
Dental floss (heat helps)
Goo gone or equivalent to remove residue
Remember to use some good glaze/polish and wax afterwards
I left mine off for a cleaner look, I don't need to advertise
Chris84Cab 02-15-2009 02:07 PM
I may do the same... thanks m110.
Wickd89 02-15-2009 02:16 PM
after removing.
Spray some goo-gone and it works the remaining glue off.
Then use some Scratch-X to get rid of the dirt that built up around the emblem.
