86 electric seat motors
I am putting 86 power seats into my 83.
Everything is going well (e.g. put in power for both seats and replaced a couple of bad switches)
The issue that I am having is the rear lifter gear (i.e. that raise and lower the rear portion) on the drivers side is stuck. When I press the switch, the flexible drive train attempts to do it part, but the seat does not raise or lower.
The front lifter gear is working fine.
For those of you who have a Bentley Manual for an 86 does it show how to remove the motors? if so, could you fax those pages to me?
I am open to suggestions, but it appears that I need to replace the rear lifter gear.
Brad
1983 911 Cabriolet (daily driver)
2000 ML 320 (Shared by teenagers)
2005 Pilot (Wife's)
Old 03-01-2009, 07:08 PM
I have the Bentley Carrera book
it's only 1.5 pages of installing'removing seats and 1 page of motor and cable removal
1] detach cable from motor by prying spring clip from end of cable
2] remove two mounting screws [it's above clip] and detach motor from seat frame
3] angle motor out of seat frame
seems like the detaching spring clip is right at the end of cable directly under those two screws. It seems to wrap around the cable.
if you want a fax of 2 pages
1] hit my user name
2] hit e-mail with your phone number
there's really not much to it once you find and pull back that spring clip
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-01-2009, 08:55 PM
1] hit my user name
Here is the part I need to replace:
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?command=show_parts_image&Headers_Id=39042&Line_Item_Number=5
fax is 800-549-8022
Brad
2005 Pilot (Wife's)
Old 03-01-2009, 09:28 PM
1] hit my user name
I am heading out to the garage to take the seat out and will try your instructions--Thanks, Brad
Brad
2005 Pilot (Wife's)
Old 03-01-2009, 09:29 PM
I'm standing by
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-01-2009, 09:43 PM
