naturally aspirated
Things to bring to DE
Sorry if this was discussed, I tried the search first. I'm attending my first DE. Just wanted to make sure I remember to bring what I need:
Helmet Stamped Tech sheet Group listing sheet and schedule Basic tools The weather isn't looking to good for tomorrow over here, umbrella is on the list. anything else? |
Chair
Cooler with water, snacks Tarp to put in paddock to lay stuff on Oil Windex/paper towels Pressure gauge I have a big checklist if you want it.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
Chair
Dont forget your car
abit off center
cigars
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Registered Abuser
A DE check list woul be great please post! I was just going to start one.
MT 930 1987 930 - Gone but not forgotten A man with priorities so far out of whack doesn't deserve such a fine automobile. I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen американский |
Here's my List
Murphys law......
If you think you will need it or it could break take it with you brake fluid torque wrench extra tune-up parts plugs cap etc. It's a DE but I have seen a few weekends ruined trying to chase down a two dollar part.
Tony Proasi 1969S 1957 VW Pickup |
Driving member
Don, that is a pretty good list.
I would add bringing a spare DME relay, Dist. cap and rotor and fan belt. I always carry these in my car anyway but at the track it is even more important IMHO. If you have them then you probably won't need them.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Black and Blue
dont for get the camera so you can post some Pics!!!
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Something to wipe that silly grin off your face...
joe >82 3.0 SC >01 Audi S4 Avant |
Driving member
It is also important to bring all the required forms.
They are different for each club but here are a few I have had to bring. Helmet form Tech inspection form Health form Waiver I usually have a large manila envelope I carry those and my numbers so I keep them together.
If you have adjustable sway bars, bring the tools needed to adjust them.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Here is mine plus here is my nuts and bolts check for prep:
Track Prep List Registration Stuff Signed/completed Tech Form Schedule and run group listings Driver’s License Car Stuff Window Cleaner/ Paper Towels Motor Oil Extra Brake pads Brake Fluid Brake Bleeder Cover-Alls (Clean) Tire Pressure Gauge Racer Tape For Head Lamps/Marker Lights Tools (Wrench set and socket w/ toolbox) Jack / Stands Torque Wrench Wax/ Car Duster Quick Detailing Spray with Car towels Car Cover? Mirror Bras Funnel Jack Wood/ small ramps Rubber Gloves Work Gloves Magnets/ Magnetic numbers Helmet/ Gloves/ neck brace Knee pads Blue boxes with lids Other Stuff Lawn Chairs (No need at Mid-Ohio) Sun Block/Hat Ant-Acid Magazines/ Books Bug Repellent if going to Nelson Ledges Camera Digital Wallet Maps/Directions Tent or Tarp for more shade (No need at Mid-Ohio) Air Mattress Clothing Boxers Long Sleeve shirts and kakis/Jeans Rain coat/rain pants/boots / Umbrella if weather looks bad Jeans Running Shoes Glasses Bath Stuff (Including Contacts) Long-Sleeve T-Shirts Socks Ball cap Watch Tools Yellow Tool box Pliers Multi-Screw driver 3/8” Metric Sockets ¼” Metric Sockets 3/8” and ¼” Extensions Spare Parts o Fuel Pump o Cap/Rotor Electrical Tape Brake Pad Spreader 17mm Hex Socket Metric Allen Wrenches 3mm Long Allen Wrench Mirror JB Weld Hammer Punch for brakes Wonder bar Crescent Wrenches Rubber Gloves Work Gloves Tape Measure Zip Ties Nuts and Bolts Checklist: Pre-Track Nuts and Bolts Checklist Left Front Caliper Bolts (2) – 19mm Caliper Bleeder Bolt (1) – 9mm A-Arm Bolts (4) – 17/19mm Tie Rod End Bolt (1) Pads and retainer Pins (2) Bearings Sway Bar mounts (2) – 17mm Brake Cooling Scoops & Hoses Strut Top Nut (1) – 22mm Ball joint nut retaining pin present (1) Lugnuts (5) Right Front Caliper Bolts (2) – 19mm Caliper Bleeder Bolt (1) – 9mm A-Arm Bolts (4) – 17/19mm Tie Rod End Bolt (1) Pads and retainer Pins (2) Bearings Sway Bar mounts (2) – 17mm Brake Cooling Scoops & Hoses Strut Top Nut (1) – 22mm Ball joint nut retaining pin present (1) Lugnuts (5) Left Rear Caliper Bolts (2) – 19mm Caliper Bleeder Bolt (1) – 7mm Swing Arm Bolts (6) – 17/19mm Alignment Bolts (2) – 19mm Lower Shock Bolt (1) – 22mm Upper Shock Bolt (1) – 17mm Pads and retainer Pins (2) Sway Bar mounts (4) – 13/19mm Lugnuts (5) Right Rear Caliper Bolts (2) – 19mm Caliper Bleeder Bolt (1) – 7mm Swing Arm Bolts (6) – 17/19mm Alignment Bolts (2) – 19mm Lower Shock Bolt (1) – 22mm Upper Shock Bolt (1) – 17mm Pads and retainer Pins (2) Sway Bar mounts (4) – 13/19mm Lugnuts (5)
Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
Need tools at DE?
Mike,
Welcome to your first DE. In case you need tool/s at your next DE, and don't feel uncomfortable borrowing it from other members, simply go to Dougherty's service trailer. Bill or Jim are always willing to assist DE drivers in their desperate moments. Enjoy and share with us your experience. Good luck. Tony Last edited by boyt911sc; 02-15-2009 at 07:53 PM.. |
Driving member
One great thing about going to the track. If you forget something someone else almost always is willing to share with you. It is really impossible to bring every possible need but usually someone in the paddock has it within reason.
The thing to do is find the sweet spot between on the one hand bringing nothing but a helmet and, on the other, preparing for LeMans. I used to bring stuff like spare brake pads and finally realized it'd be awhile before I drove hard enough to wear out the ones I had. You can always borrow tools; somebody will always be happy to not only lend them but help if you seriously break something.
Particularly if it's your first DE, you're not going to be tweaking swaybar settings and re-timing the distributor, and you're not even going to be doing anything with tire pressures other than making sure they're inflated and then some. You'll have plenty of time down the road to start playing with stuff like that, once you've found your way around the track and simply begun to absorb the basic stuff. I'd suggest concentrating more on the comfort stuff--sunglasses, sunblock, something to drink, somewhere to sit, a tarp or blanket on which to spread everything out, big trashbags to cover things if it rains, good driving shoes, camera for fun, a carton into which to put all the stuff you remove from the trunk and glovebox, etc. etc. etc. than I would on worrying whether you have enough tools to do an engine drop. You'd be amazed how quickly the time passes between run groups; by the time you've unwound from the first session, it's time to line up for the second one. Sure, bring a spare quart or two of oil and a funnel, have an extra fanbelt aboard, but stuff like brake fluid is a waste of space unless you have the kind of leak that would get you disqualified at tech anyway. You're _not_ gonna be going fast enough to boil it off. And if you are that fast during your first DE, the talent scouts will be all over you...
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
The previous points about simple prep are good and I agree with them for your first and second seasons. The above lists that I posted were put together over my previous 7 seasons of DEs and serve mainly as a checklist for me. I obviously over pack.
THere is never a problem borrowing tools, jacks, or parts from others.Just bring oil, brake fluid and personal comfort stuff and you will be fine.
Noel, I did realize that yours was a serious race-prep list, not intended as first-DE advice.
