Formerly known as Syzygy
Canada Kev's Avatar
Top end break in
After a top end rebuild, should one treat the engine in a similar fashion to having a complete rebuild, or is this overkill? I know I should get a valve adjust and oil change in a few miles or so, but should I drive it any differently?
Old 04-02-2009, 06:33 AM
Almost Banned Once
sc_rufctr's Avatar
You should drive your car gently for at least 500 miles.
Then do the valve adjust and oil change and all should be good.
The 500 miles is important.
- Peter
Old 04-02-2009, 06:42 AM
Zeke's Avatar
By top end, do you mean new rings? The ring and cam break in (if you refreshed the cams) procedures would need to be followed. As the rings and cylinders get to know each other, they will add metal to the oil. I'd change the oil at 100 and 500. If you just did the heads, drive it normally.
Old 04-02-2009, 07:38 AM
Air Medal or two
afterburn 549's Avatar
for ring seating you would not use syn oil, and not drive it gentle
A little search and you will see why the "gentle" thing is all wrong
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 04-02-2009, 09:52 AM
Canada Kev's Avatar
Sorry, I guess I wasn't very clear. Heads off, valve and guides. Basically just a valve job. I know I should do a valve adjust and oil change after some miles, but do I need to baby it or not drive long distances, or drive like normal.
Old 04-02-2009, 03:46 PM
Senior Member
Superman's Avatar
Drive like normal.
Mocha 1978 911SC. "Coco"
Old 04-02-2009, 04:00 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Drive it normally and re-adjust the valves after 500 miles or so.
Gary R.
from my experience the engine will produce great power after a top end refresh since the rest of the engine is already nicely broken in.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 04-02-2009, 06:41 PM
