LinkBack Thread Tools Rating: Thread Rating: 4 votes, 3.00 average.
MFI Open Heart Surgery II - The Fuel Pump
I guess we all know how hard it is getting to find good MFI fuel pumps these days. "NLA" is the order of the day. Well, I found myself in need of one, and even with three on hand, none of them worked. Two didn't run at all, and one leaked out of the electrical connector base. I figured it was time to dig in and see what these are all about. After all, I had two chances to ruin non-working pumps before I had to figure this out and make one work. With nothing to lose, I went to work.
Here is a shot of the pump, even though most of you know what they look like:
The pump itself comes off of the motor with four screws. Here is what it looks like once off of the pump. Note the star wheel and little rollers. Those rollers are loose - don't lose them:
Take the rollers out and put them aside. The pump now looks like this. Note the tiny little hole at about 11:00; gas passes through that hole into the motor itself. The motor runs wet, i.e. it is full of gas and pressurized:
Next, the star wheel is removed from the shaft. The drive pin is pressed into the shaft, so there is no danger in losing it:
Now the fun starts. The endbell needs to be removed from the motor case. It is staked on in several places around the case. I inserted a screwdriver into the square notches on the endbell, and twisted to release the staking:
You will have to work at it, but the endbell will come out. With it will come the armature, commutator, brushes, and all of that.
Once it is all out, it will look like this. Note the thrust washer and shims - these go on the shaft end that slips into the bearing in the motor case. There should be two shims and a thrust washer:
Make sure you get all of the shims out of the motor housing. They are steel, and will want to fall off the shaft and stick to one of the magnets in the housing:
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 02-16-2009, 05:40 PM
...con't:
The o-ring that fails is located in a groove where the endbell presses into the motor case. This one was so brittle it came off in two pieces:
This is a good time to take a look at the brushes and commutator. These weren't all that bad, but it would be easy enough to turn the commutator and put brushes in it. Clean everything (including the motor case) with some brake cleaner, electrical cleaner, or whatever.
The o-ring is removed in this photo. Put a new one in the big shiny groove, and it's ready to go back together:
Now it's ready to go back together. Slide the thrust washer and shims back on the shaft, and maybe put a blob of grease on them so the magnets in the motor case don't suck them off the shaft. Grease up the o-ring as well, and slide the whole works back into the motor case.
One the endbell is seated, stake the case back over it. I just used a punch and bent the tabs back in:
From here, all you have to do is reassemble the pump half. Don't forget to put a new o-ring in the groove on the endbell, around the pump mechanism.
That's it, that's all. Pretty darn easy, really. I hope this helps some of you in getting those old dried out MFI fuel pumps working again. God knows they ain't making any more of them.
Jeff
'72 911T 3.0 MFI
Old 02-16-2009, 05:51 PM
fuel pumps
Great post!
Where did you find the o-rings?
Old 02-16-2009, 05:57 PM
jpahemi's Avatar
Jeff:
How are the sparks from the brushes shielded from the gas vapors?
jp
Old 02-16-2009, 07:00 PM
I found the o-rings at the local auto parts store. They are nothing special. I just brought the old ones in and matched them up with what they had.
The commutator and brushes are not shielded at all from the gas; they don't have to be. D.C. electric motors actually run quite well underwater, or in this case, under gasoline. When my son was younger (the son I'm building this car with) we used to race radio control cars. It was common practice to break in their motors by running them underwater. Kind of counter-intuitive, for sure.
Jeff
'72 911T 3.0 MFI
Old 02-16-2009, 07:28 PM
jpahemi's Avatar
Jeff:
Never knew that, always thought electric motors had sparks when running; I remember seeing some kind of spark when looking in the vent area??
jp
Old 02-16-2009, 07:38 PM
Never banned
sc_rufctr's Avatar
Modern cars with fuel pumps either inside the gas tank or external run "wet"...
(The fuel acts as a coolant for the pump)
Kinda weird when you think about it...lol...
Old 02-16-2009, 08:01 PM
Senior Member
Ron,K's Avatar
Jeff,
I just went through this exercise but had trouble getting the pump to run. I suspect that the O-rings I used on either side of the impeller were to small. If I loosened the the screws holding the impeller it would run, but would not seal. I'll have to try some larger O-rings. I was not aware that gas entered into the motor casing. I actually need to have some work done on the commutator but I was reluctant to pull the shaft out for fear of not being able to seal it when it was reassembled.
Ron
69 911T
Old 02-16-2009, 08:05 PM
I would rather be driving
jpnovak's Avatar
Jeff, Great post. I have a siezed one on the bench that I have wanted to tear into but have not had the time. btw, this procedure will work for the carb version of the fuel pump that is also NLA. These rotary vane pumps run quiet and will deliver a lot of volume.
Old 02-16-2009, 08:06 PM
Thanks Jeff,
Now I won't be tearing mine apart blindly when the time comes.
Marv Evans
'69 911E
Old 02-16-2009, 08:22 PM
Max Sluiter
Flieger's Avatar
Wow, great timing. Mine failed this Saturday.
Great photos and informative procedure.
911S
1971 chassis, 2.7RS spec MFI engine, suspension mods, lightened
http://www.flickr.com/photos/max_911_fahrer/
Old 02-16-2009, 08:49 PM
Hi Jeff ... Great Post.
Did you do anything with the pump head? There is a pressure relief valve with a piston and spring behind that little aluminum cap. I pulled one apart awhile back and that valve was stuck from old fuel. I ended up sending it out to have rebuilt and they replaced a part in there and installed a new cap.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 02-16-2009, 09:49 PM
pwd72s's Avatar
Great thread...a link going off to Istanbul!
Old 02-16-2009, 11:13 PM
Nope, I didn't do anything with the pressure relief. I was lucky in that one of mine was quite clean inside, so that's the one I used. One of the other ones leaks, so I assume the thing is stuck, but that's a project for another day. We have lots of other things to do on my son's car to get it on the road. When that is all done, I'm going to have a peek under that leaky pressure relief cap. I bet there is another dried out o-ring under it.
Jeff
'72 911T 3.0 MFI
Old 02-17-2009, 05:23 AM
Warren Hall Student
Bobboloo's Avatar
Great stuff Jeff! Sent a recommendation to put it in the Wiki.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 02-17-2009, 07:58 AM
Max Sluiter
Flieger's Avatar
What size O-rings are needed to do a full rebuild on the pump? I am going to tackle this project very soon and want to get a parts list together?
Thanks for any tips
911S
Old 02-19-2009, 11:35 AM
Max Sluiter
Flieger's Avatar
How much fuel came out of your lines when you removed the fuel pump?
I am curious to how much is contained in the lines between the fuel pump (on the rear sway bar mount) and the MFI pump. Also, the lines running forward to the tank.
How do you cap the fuel lines? I may need to have the pump off the car for a while so I hope to keep debris out of the fuel circuit and fuel pump while the pump is on the bench and disassembled.
911S
Old 02-19-2009, 09:42 PM
Originally Posted by jpahemi View Post
Jeff:
jp
Even if there were sparks, there's no air. Liquid gasoline does not burn - the vapors do. A tank half full is a dangerous thing to keep around when your playing with fire - a completely full tank is not.
There was a link to an aircraft site a while back (in one of the efi-conversion threads I believe) where the author talked about fuel mixture. In explaining the above scenario, he even said something along the lines of: light a match, throw it on the ground, and pour gasoline on it. It will go out.
Old 02-20-2009, 12:54 AM
al lkosmal's Avatar
Pump rebuild
Jeff,
Very nice job. I love to rebuild rather than replace. Have you ever rebuilt one of these? I have four of them. One works. I have yet to figure out a good way to remove the top cap to get at the innards.
RGruppe #669
http://www.x-faktory.com/
Old 02-20-2009, 07:11 AM
tharbert's Avatar
You could use a Dremel to make slits in the bell that fits over the lip and gently pry each newly made tab out. It might be an academic endeavor as I think you would be hard pressed to find a way to seal it back up especially if it's under pressure. And the cap looks like steel while the body looks to be aluminum. Tricky!
As for the MFI pump, I had just the pumping portion apart on mine. Fortunately, my pump was gummed and the brushes were stuck. As soon and I had it apart and turned the shaft a few times by hand, I hit it with a trickle charger and it spun up right away. 37 years old! I'm always amazed by this car. I cleaned up the star and rollers, slapped it all back together, and it works great. I still wish I had a spare on the shelf!
Old 02-20-2009, 07:24 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
