83 CHECKER
are crush rings needed for tranny plugs
I got my trnsmission fluid changed last fall and noticed he did not put new crush rings on the fill or dran plugs, I'm not sure if the even have them, but since it has been dripping fluid and prior to the fluid change it never leaked a drop. Do the plgs require crush rings like the oul plug does?
'83 911SC CAB
'90 ZR-1
'68 TR-250
Old 02-19-2009, 04:35 AM
UnRegistered User
billybek's Avatar
Tapered thread plug. No shoulder for a crush ring on them.
I have read here that some people use a small amount of Teflon tape on the last bit of thread on the plug (not the leading threads going in) plus a bit of anti seize.
I just used some aluminum anti seize and had no drips.
Bill K.
Old 02-19-2009, 04:56 AM
Almost Banned Once
sc_rufctr's Avatar
Teflon tape x2... I use it on the gearboxes and engines of my VW Golf and Porsche. No drips here...
Old 02-19-2009, 05:40 AM
Slumlord
Porsche_monkey's Avatar
Teflon paste.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 02-19-2009, 07:21 AM
burgermeister's Avatar
Just for completeness, the G50 needs crush washers. Unless my mind is playing tricks on me.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 02-19-2009, 01:08 PM
83 CHECKER
Thanks I got the answer I was looking for.
'83 911SC CAB
'90 ZR-1
'68 TR-250
Old 02-19-2009, 01:28 PM
dshepp806's Avatar
Your mind is fine,..it (G50) uses the washers....no tape,...no "goo",..just the magic crush.
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 02-20-2009, 02:20 PM
