83 CHECKER
are crush rings needed for tranny plugs
I got my trnsmission fluid changed last fall and noticed he did not put new crush rings on the fill or dran plugs, I'm not sure if the even have them, but since it has been dripping fluid and prior to the fluid change it never leaked a drop. Do the plgs require crush rings like the oul plug does?
'83 911SC CAB '90 ZR-1 '68 TR-250 |
UnRegistered User
Tapered thread plug. No shoulder for a crush ring on them.
I have read here that some people use a small amount of Teflon tape on the last bit of thread on the plug (not the leading threads going in) plus a bit of anti seize. I just used some aluminum anti seize and had no drips.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Almost Banned Once
Teflon tape x2... I use it on the gearboxes and engines of my VW Golf and Porsche. No drips here...
Slumlord
Teflon paste.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Just for completeness, the G50 needs crush washers. Unless my mind is playing tricks on me.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
83 CHECKER
Thanks I got the answer I was looking for.
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
