Swapping out the DME relay?
I know this is about as basic a job as it gets, but is there a link on Pelican (or anywhere else) with instructions on how to replace the DME relay?
1986 Targa
1968 MGB (2)
Old 02-25-2009, 05:48 PM
m110's Avatar
Push driver seat all the way back, remove front carpets, unscrew retainer screw, unplug, replace, reverse.
1988 Carrera Coupe
Old 02-25-2009, 05:52 PM
While your at it, put a spare in the glove box, turn knob, door will fold forward, after putting spare in the box, just push door closed.
'85 RoW 911 Coupe
'65 356 SC
'72 BMW 2002Tii
'10 Cayenne
'20 Ram Longhorn
Old 02-25-2009, 07:41 PM
Make Bruins Great Again
Por_sha911's Avatar
10 mm 1/4 drive deep socket works great
Joe
Old 02-25-2009, 07:48 PM
Thanks for your patience with my very basic question. Will give it a shot.
Oh, and 'tomphot', I appreciate the tip re the glovebox.
However, you might want to pick up a book on how to write English properly:
"While your at it . . ." should be "while you're at it."
But thanks for the sarcasm in any case.
1986 Targa
1968 MGB (2)
Old 02-26-2009, 01:25 PM
Wash. State
nesslar's Avatar
Quote: "While your at it, put a spare in the glove box, turn knob, door will fold forward, after putting spare in the box, just push door closed."
Pretty funny....even if not getting an A from the teacher... *&^% good advice!
Old 02-26-2009, 01:30 PM
Of course you're correct - Sometimes my fingers get ahead of my brain
btw - I had a friend stop by the house a couple of weeks ago - when he got in his '85 to leave, it wouldn't start. Luckily, he had a spare in the glove box, we plugged it in and off he went.
'85 RoW 911 Coupe
'65 356 SC
'72 BMW 2002Tii
'10 Cayenne
'20 Ram Longhorn
Old 02-26-2009, 01:32 PM
Wash. State
nesslar's Avatar
Seriously, I don't really think any sarcasm was meant, anyway, just a sense of humor being shared. Regardless, the job is easy, you'll see when you "get in there". I know, 'cuz I done it..... Lar
Old 02-26-2009, 01:34 PM
burgermeister's Avatar
Disconnect the battery.
The plug on mine was very tight, trying to unplug it with lots of force pulled the cover off the relay and sent my hands banging around under the seat, causing bloody knuckles and a dropped relay and relay cover. The relay has some permanently live contacts that arc nicely against whatever they hit. That way you can wonder what else is getting fried as you try to reassemble the relay under the seat while causing lots of ozone.
Or, disconnect the battery and don't worry about it ...
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 02-26-2009, 02:20 PM
RETIRED
Joe Bob's Avatar
By an SC....problem solved....
2012 ML350 3.0 Turbo Diesel
Old 02-26-2009, 04:21 PM
