more PM's than Posts
NY91184's Avatar
Porsche Crest 3 More to Go! (wheel content)
I had some free time this week and decided that I was going to try and "restore" my wheels to some extent. After the tranny blew in March 08, the car sat outside (under a cover in a carport) untill recently when I started refurbishing different things that bothered me. Ive never stripped and rebuilt a set of 3 piece wheels, so this attempt is purely experimental. Below are the pics and steps that I used on the first one, any comments would be appreciated. I found leaving a junk tire on (without air) and leaving the seal between the barrels worked well. The tire protected the edges while moving it around during the process. I think I spent around 5 hours from start to finish on this wheels, I would imagine the other 3 take half the time now that I have a method to the madness.
The starting point:
I first removed all the bolts, cleaned them up with a wire brush, and polished them with a dremel attachment using chrome polish.
Then, leaving the inner and outer barrels sealed, removed the center section. The inner barrel was "rusted" from old brake dust, and I figured while I had it all apart, I would come up with a way to remove it. I used a paint stripping bit with a drill and ran it all round untill the surface was smooth. *note* make sure to wear a respirator when kicking up the dust, not safe to breathe. Then I used 1K grid snadpaper and brought it up with 2Kwet. I then used a multimetal polish to finish it off.
Then I moved onto the outer lip. I used Noxon to get the tarnish out, then used mothers "Billet" cleaner for the final polish. Did it all by hand to avoid swirling.
I used a solvent with alcohol in it to clean off the center section, then hand polished it with standard car wax.
Time for reassembly. Made sure my hands were clean so I wouldnt mark up the fresh work and loosely mounted all the bolts to hold the center section back in. Then I placed the rim on its face and torqued all the bolts to aprox. 45ft/lbs in an "X" pattern.
Old 02-24-2009, 04:13 PM
Wow! Very nice!
Dom
1985 Black 911 Targa (Sold)
2007 Chev Malibu SS (wifey's car)
Old 02-24-2009, 04:25 PM
Mark Dia Gruppe's Avatar
Looks great! Did you make sure to put the center back in the same exact holes as before? the balance of your wheels might be off now, I did the same thing a few years back and had that problem and found out why.
Mark Hutchinson
1984 Guards red Carrera M491 Factory Turbo-look
Old 02-24-2009, 04:29 PM
NY91184's Avatar
Thanks for the reply, I did clock the center slightly in order to line up the valve stem with a spoke rather than being out in the open, hopefully its still pretty close. I will have the wheel/new tire balanced before the car is driven so any inperfections should be taken care of then.
Old 02-24-2009, 04:33 PM
Living up to the name
VroomGrrl's Avatar
Wow is that inspiring! Beautiful detail work!
Here's one detail I recently learned about - when returning the center caps, the bottom point of the Porsche crest should be pointed toward the valve stem. WHO KNEW? Yours here is very close
2008 911 (997) C4 Carrara White
The sweet old 1988 911 GP White has gone to a new owner
"Keep your head in the clouds and your right foot mashed to the floorboard!" ~Village Idiot
Old 02-24-2009, 07:54 PM
tangerine911S's Avatar
Wowza!
Old 02-24-2009, 09:04 PM
NY91184's Avatar
Thanks for all the positive feedback, it makes me motivated to finish the other 3 wheels so I can update the thread. I can't wait to see how the rears come out, they have 3" stepped lips Im still amazed they are comming out as good as they are, I'm far from a professional but a little (lot) OCD goes a long way
Old 02-24-2009, 09:21 PM
NY91184's Avatar
Update!
Finished one of the rears over the past 2 nights, it actually took longer than the first one because I spent around 2 hours on the lip alone. I also had some extra work in repairing some gouges from tire machines clamping the inner barrel. Very satisfied with the results, and im 1/2 way done now!
Old 02-27-2009, 10:00 PM
Carrera Cab Connoisseur
nyne11's Avatar
They look fantastic! Well worth the effort!
Dave
1986 Carrera Wide Body Cabriolet
1993 Nissan 300ZX Twin Turbo (620rwhp)
2003 BMW 330Ci MSport Individual
1973 Mercedes 350 Custom Convertible
Old 02-27-2009, 11:26 PM
AirBorne!
Wow, good work. I couldn't help but notice the "untidy" shop you maintain. I feel much better. I put all my "tidy" work into my cars, my shop is a wreck. I don't care. LOL>
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed
Old 02-28-2009, 04:16 AM
chrisp's Avatar
Looks amazing.
Where did you get the torque spec? I recently researched this and consensus seemed to be around 200 in/lbs. but varied by wheel mfg. Yours are at 540 in/lbs.
Just curious.
'83 SC
Old 02-28-2009, 04:56 AM
grateful user
don gilbert's Avatar
nice
this is nice and very timely for me as i just got these bbs motorsports (9x17&11x17) and must do the same thing. i am new to 3 piece rims, and have a few questions. when does the tire come off? do you have to split the rims to get the tire off or is it safe to put on a tire machine, the rim halves are very thin, and it worrys me. do the 2 o-rings need to be replaced, and can i sand or bead blast the forged magnisium center? ny911, those came out nice, and i know how time consuming that was. good job.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 02-28-2009, 05:21 AM
NY91184's Avatar
Its funny, the shop is extremely messy, yet I know where everything is within a few inches. Ive attempted to clean it before but then I cant find anything for weeks and it eventually morphs back into a mess. Ive come to terms with this cycle.
Originally Posted by chrisp View Post
Looks amazing.
Just curious.
I used a torque wrench to remove a few and "sampled" the torque they were originally at. Some were around 35, some around 40. Speaking to a few rebuilders, it seems 28-30ft/lbs is average so I probably overtightened mine a little, but I reused my bolts so id rather be safe than sorry. 200in/lbs seems light, that almost seems like a 2 piece rim spec rather than a 3pc. As far as the BBS MS wheels, very nice find. Expect to put atleast 10 hours into each one, then stare at them for an equal amount of time when you finish. Be careful what polish you use on the centers so the finish doesnt get damaged. I dont know for sure on those if you can mount them with a machine, I would contact "bob barnes" on here, he seems to know a good amount about those wheels.
Old 02-28-2009, 10:38 AM
chrisp's Avatar
You may want to look into your torque spec. I wouldn't use a breakaway torque as my baseline....especially considering the corrosion on those bolts.
Over torqued rim bolts could be a time bomb ticking.
'83 SC
Old 02-28-2009, 11:12 AM
NY91184's Avatar
Point taken, are there any websites with mfg. torque specs for different brands? My second problem would be determing the brand of these wheels since they arent marked. For those interested, wheel bolts should not be reused, I just did it for budget/availability purposes. These are also my street wheels, not my track wheels.
Old 02-28-2009, 11:29 AM
Slumlord
Porsche_monkey's Avatar
For those interested, wheel bolts should not be reused....
Why would you say that? They aren't stretched at install are they?
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 02-28-2009, 11:38 AM
chrisp's Avatar
try this. i can't confirm it's accuracy...but it's one of the first few to pop up on google.
http://www.engineershandbook.com/Tables/torque1.htm
'83 SC
Old 02-28-2009, 12:49 PM
FANTASTIC!! Man do those look sharp. Have to post pics when they are back on the car.
O2 In Sully We Believe
Old 02-28-2009, 01:05 PM
NY91184's Avatar
Not that i majored in Mech. engineering (I majored in automotive eng.) but I recall that heat is a much bigger factor than overall torque in failure analysis. If a bolt is tightened to a desired torque, the deformation will occur in a more static way opposed to if heat was added and plastic deformation was a factor. Example being alu. heads being over/under torqued on a iron block. On another note, I discovered my torque wrench was out of spec by around 7%, which would make my actual torque lower (especially when the extension is taken into effect). To answer the above question, all bolts stretch to some degree when torqued. I believe the hardware on these wheels is 10.9 rated
Old 02-28-2009, 01:23 PM
