Has anyone gotten rid of auto-heat?
As the subject says, I am trying to get rid of auto-heat and go back to manual controls in my 1984 Targa.
And yes, I tried the search function, but I could not find anything. I have the module apart, but there seem to be an awful lot of wires underneath, unlike the previous versions. Has anyone done this retro-fit before? Thanks. Here is where I am at:
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
My car has (had) auto heat. My 79sc has a manual lever on the right side so i just use it to adjust the heat. I don't see the lever in your picture so you might have to source one or figure out some way to use the existing arm (what the disconnected end of your rod was snapped on to) to regulate the heat.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
usually the flapper boxes rust, stick and and then pull the ball end off
inside the auto heat. Make sure you check that they are not stuck. might be nothing wrong with the elecs. in your pic. |
I have a euro-spec 911 SC with auto heat - I ignore it and use the lever to adjust and flapper valve on the heater boxes.
Kim Langley 2012 Carrera / 991.1 80 911SC 97 C230 73 BMW 2002Tii |
Thanks, guys!! Mine never came with the levers, so I may just swap over the brake handle to one with the levers. I am also seeing whether or not I can install a switch for the footwell blowers.
Yes I did. Works well as a cup holder.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
