Need a pic! Early Turbo engine Fuse/Relay panel
Looking for a pic of the engine compartment fuse/relay panel from an early Turbo 76 etc. I have one but need to know if its from a Turbo that was in our 1974 911 Turbo.
Thanks' |
Bump, I want to see how this turns out! :)
Mike, It appears to be a 74 turbo prototype but I would like the rear panel to confirm with the intact wiring which mates up with the panel we do have.
Craig, you might want to post this over on the turbo forum too, there is a good chance someone over there will have the information you're looking for. You might want to post somewhere with a larger European presence since the turbo came out there in 1975 just in case there were any changes for 76 stateside.
| All times are GMT -8. The time now is 10:08 AM. |
