A/C Compressor in car with nopressure
I know this is a dumb question, because I couldnt find anybody else who askd it and I know nothing about A/C systems
Does leaving the A/C compressor in the engine bay hooked up with the belt but having no pressure in the system eventually ruin the compressor? Obviously, not trying to use it for cooling purposes I ask because the system has been empty for some time and I just disconnected a condenser hose... I plan to continue to run it this way for a while. Thanks in advance |
Not as long as you don't turn it on. When it's off the clutch won't engage so the compressor itself doesn't turn. The OE systems don't have any low or high pressure cut out switches though, so if you turn the AC system on the clutch will start and it has to have refrigerant to keep lubricant in the compressor.
You could also just remove the belt. |
Take the compressor off and leave the mount - save some weight, free up some room. It's an easy job. Also the trunk/grill mounted evap, just a few screws and hoses, and you'll get more air in the grill.
BEFORE http://forums.pelicanparts.com/uploa...1235341724.jpg AFTER http://forums.pelicanparts.com/uploa...1235341774.jpg |
I actually preffer AC in a street car, especially one I spend 2-3 hours a day on, I'm just going to have to find a better way to plumb the AC Thanks for your help |
I just spent last summer baking my arse off and the last few months not being able to see a thing for a good 20 minutes in the morning. I repaced the blower motor yesterday. Now I'm going to have to find a solution for the AC. Having a 3.6 in an SC/Carrera chassis does create the need for a few interesting work-arounds. |
If you take it out of the car, you should close up the connections from the liquid line and suction line of the AC (hi side and Lo-side) The best solution would be to find an AC tech to evacuate the compressor and store it in a vacuum. Another alternative is to positively charge it with nitrogen to about 25 lbs.
This would keep the internal parts rust free for you. |
| All times are GMT -8. The time now is 06:37 PM. |
