engine to transmission torque settings
got the transmission mated up with the engine! just trying to find out what the torque value is for the engine-to-transmission studs that run through the bell housing and the starter. searching the forum didn't show anything.
just to clarify, i'm not asking about the 4 donut mounts, i saw an earlier post from Warren Hall that confirmed those engine and transmission mounts as 58 ft/lbs thanks!!!! |
SC Bentley manual says 45 Nm (33 ft-lb).
| All times are GMT -8. The time now is 05:32 AM. |
