Detached Member
Hugh R's Avatar
Dead Short inside Fuel Injector kills whole car
Car stopped dead last Tuesday. I had it towed to TRE and they poured over it for several days. Indicators were no voltage to fuel pump, no injector pulse, no power at DME. DME relay good. Found that a bad #4 injector electrics was backfeeding to the injector harness. Replaced the fuel injector, and car works. I ate some costs on this, but graciously so did TRE, because they've never seen this problem and symptoms before. My first experience with TRE and I don't feel like I was screwed at all (even though my wallet is hurting a little). Thanks to everyone at TRE.
Hugh
Old 08-22-2005, 04:19 PM
I know this is old... but what were the symptoms? Im having electrical issues as well.
http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series-e30-e36-1982-2000/526053-need-major-help-electrical-issues.html
Here is my problem.. thanks
Old 02-11-2010, 10:24 AM
porsher
aston@ultrasw.c's Avatar
you are lucky it stopped dead ;-)
i chased an intermittent hesitation for 6 months, that ended up being the injector wiring harness!
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 02-11-2010, 11:05 AM
Detached Member
Hugh R's Avatar
Car was running fine, and it was like the ignition was turned off. Crank and no spark, nothing. TRE repaired it and said they'd never seen it before. Sent a screwy or no signal back to the DME.
Hugh
Old 02-11-2010, 11:09 AM
