But how many gallons did you fill? 2 gallons after a 50 mile test drive or 16 gallons when the spare tire bubble is full of air? Assumptions, assumptions....assumptions. |
tire pressure to factory specs, standard size tires, aligment has been checked, can check afr no load at 3200 and let you know, JL
Update!!! plug wires and distributor cap tested perfect with ohm meter. Put a set of magnecors on and a new distributor cap and it was worth 2 Mpg, JL
| All times are GMT -8. The time now is 03:27 AM. |
