1982 911SC
Semba's Avatar
Rims
I thought I would clean up my rims today. Started with 2000 wet sanding and then polished that area which was already blemmished. What I now have is a very shiny blemmished area and the rest of the rim looks dull (pics 1&3). It appears there is a coating over the aluminum, I don't know if this is factory or done later since the centers were painted (not by me). I think I know the answer which is good luck and sand the rest of the rim out and finish? Anyone else run into this? Is there a better way? Originally posted this in the wrong forum
Gary
Old 02-26-2009, 04:01 AM
The original wheel rings are anodized so it looks like you sanded through the anodize. Lots of guys remove all the anodization and polish the rings or the entire wheel. Search here and you will find tons on wheel refinishing. To restore your wheel you'd have to have the wheel re-anodized. Don't know that you can spot anodize. Ken
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 02-26-2009, 08:20 AM
Aron in Toronto's Avatar
As Tigerrat said, the polished blemished area has probably removed the "frosted" anodized surface. You could attempt to dull the bright areas with a scotch bright pad or other mild abrasive or try to match the look with some frosted clear paint to make it less noticeable.
Aron
1997 Boxster
Old 02-26-2009, 09:51 AM
1982 911SC
Semba's Avatar
Thanks guy's. The blemmished are was already there, I was trying to remove it. Looks like I have a lot more removing to do. Thanks for the input.
Old 02-27-2009, 03:57 PM
DanielDudley's Avatar
I have never done it, but I hear that oven cleaner takes off the anodizing quite easily.
Anodizing is quite hard, and not easy to sand, as you have discovered.
Old 02-27-2009, 05:07 PM
