-   -   Snap-on Stud puller collet (http://forums.pelicanparts.com/porsche-911-technical-forum/459772-snap-stud-puller-collet.html)
cgarr 02-27-2009 08:53 AM
Well, when they are out of stock you need to do what you need to do, nothing with being cheap, but these collets are not that hard to make, just need to cut the reliefs. This is a homemade 6x1.00
http://i30.photobucket.com/albums/c3...1/100_7956.jpg
http://i30.photobucket.com/albums/c3...1/100_7957.jpg
Rot 911 02-27-2009 08:56 AM
Nice work!
john walker's workshop 02-27-2009 09:34 AM
you need a band-aid.
yelcab1 02-27-2009 10:57 AM
Some homes are better equipped than other homes. My home has nothing that will turn out a piece of work like that. I do have lots of band aids.
pwd72s 02-27-2009 11:04 AM
Evren has the whole set of metric ones...but considering their cost, I've often wondered why somebody hasn't set up a rental on them...I mean, other than a full time pro, how often do you need them?
Great Job of making one!
86911cab 02-27-2009 11:25 AM
I didn't even know band-aids came in metric! I gotta get me some, cause rentin 'em is outa tha question!
http://forums.pelicanparts.com/suppo...leys/smash.gif
cgarr 02-28-2009 10:00 AM
Well its done and works great, now to make an 8mm smooth bore for pulling the dowels on the heads.
http://i30.photobucket.com/albums/c3...1/100_7958.jpg
Elombard 02-28-2009 12:08 PM
I am not 100% how it works can you show a picture of it on the stud?
cgarr 02-28-2009 04:12 PM
As you tighten up the collet it clamps down on the threads without damage then you just spin it out.
http://i30.photobucket.com/albums/c3...1/100_7959.jpg
Elombard 02-28-2009 04:51 PM
OK I just needed to see the other end. Looks like a very handy item when working on old stuff.
my1st911 02-28-2009 08:16 PM
Hey Craig, wish I had that tool yesterday. Figured that all my extraction tools would do the trick, but as you know those two gave me a hard time. I drilled out one (took me about 3 hours) and it doesnt look pretty, but should still be ok. I think i will install case saver with jb weld just to strengthen it. All others look great though. Luckily the two iffy broken studs are on different cylinders so we shall see. Any thoughts on jb welding a case saver in a not so perfect hole?
cgarr 03-01-2009 11:58 AM
Just made the smooth bore 8mm for pulling the dowels. A twist and a pull and they come right out, no damage to the dowel either.
http://i30.photobucket.com/albums/c3...1/100_7960.jpg
JFairman 03-01-2009 12:32 PM
Thats really cool, nice work.
Makes me wonder if a good quality 1/2" drill chuck could twist and pull out solid locating dowels like that. Especially if you heat the head then hold an ice cube on the dowel for a few seconds or more first.
Nine9six 03-01-2009 04:20 PM
A 1/2" drill chuck would not distribute the holding/clamping power over the same surface area as Craig's collet setup does. Perhaps the use of some shim stock around the dowel would prevent any marking/marring. However. if I had a choice, the collet would get the nod every time.
Elombard 03-01-2009 04:44 PM
Why do you even have to remove the dowels? So you can machine the surface?
cgarr 03-01-2009 06:10 PM
If the sealing surface is bad (head to cam tower) sometimes they have to be surfaced, if you have leaking in this area I bet your surface is out, and once you start to surface them you can really see why, but that does not happen often.
http://i30.photobucket.com/albums/c3...1/100_7962.jpg
