AutoBahned
RWebb's Avatar
strap on late model pedal cluster
what's this strap for on the bottom of the pic?
- it's from an SC
- is to reinforce the pedal cluster or something?
are the 4 bolted studs not enough to hold the thing in place??
should I modify my '73 so it can take one of those straps??
Inquiring Minds WANT To Know
Old 03-01-2009, 09:16 PM
Almost Banned Once
sc_rufctr's Avatar
Can't see the pics...
Old 03-01-2009, 10:35 PM
AutoBahned
RWebb's Avatar
oooops!
how about now...
Old 03-01-2009, 10:51 PM
aj88cab's Avatar
I believe that piece is a strut bar that connects the pedal cluster base to the master cylinder. Basically to stabilize the master cylinder from pushing through the fire wall when you get on the brakes. What's missing in the picture is the pushrod from the brake pedal to the master cylinder.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 03-02-2009, 12:25 AM
- it's from an SC
That's a picture of mine from my post showing my pedal cluster rebuild. In that post it was originally in or my photo site detailing my SC rebuild project, there are other pictures that show the fully assembled pedal cluster (pre- and post-rebuild) that show where that long metal strap goes. As aj88cab says, it goes from the brake pedal shaft up to the master cylinder.
Geoff
'82 911SC (Complete rebuild)
Click here to go to the project website that chronicles the rebuild process
Old 03-02-2009, 06:04 AM
Less brakes, more gas!
euro911sc's Avatar
I don't think it attaches to the master cylinder, to be specific. It attaches to the the AL housing holding the brake booster and master cyl. or maybe some sheet metal up there... but definitely not the MC. I'll look when I go out at lunch.
If you are putting in a late model brake booster, pedal cluster, and MC you may not need to mod anything there.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 03-02-2009, 06:12 AM
aj88cab's Avatar
-Michael
You are correct sir! Pretty sure it's that alum base for the booster it attaches to. it was 3:30am, what can I say
Old 03-02-2009, 06:50 AM
arbita1's Avatar
Underneath the brake fluid resevoir there are two clear plastic plugs. Remove one of them and you will see where the other end connects to.
Matt.
83 911SC
85.5 944 NA - Sold
Old 03-02-2009, 06:59 AM
AutoBahned
RWebb's Avatar
ah, so it is to stabilize all the new-fangling brakin' stuff they added....
not to stabilize the pedal cluster itself.
Old 03-02-2009, 10:08 AM
Dr J's Avatar
I did my pedal cluster about a year a go and took pics that may help.
Look in this hole. The top of that piece goes inside.
There is a bolt that comes from the outside and connect to the nut welded on the part.
Here is what it looks like with the pedal cluster out. Note the welded nut on top.
It connects to the pedal cluster via an allen bolt.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 03-02-2009, 10:22 AM
