porsher
aston@ultrasw.c's Avatar
Home Built Camber Gauge
Show off your home built camber gauge.
I know I could buy one but it's more fun to make one and save a couple of $, or not
Specs:
dedicated for 16" Fuchs,
hands free,
utilizing an off the shelf digital inclinometer.
accuracy +- 0.2deg?
Old 02-24-2009, 12:57 PM
burgermeister's Avatar
No pics ... looks suspiciously like a home depot digital torpedo level / angle finder and a milled-very-flat piece of 2x3 oak 17" or so long, with a notch taken out of the middle to fit around the center cap.
The main downside is that it reads 89.5 whether you have +0.5 degrees camber or -0.5 degrees camber ... gotta look for those little arrows.
Also gotta have a level floor - my garage floor is 0.4 deg slanted, and I need a piece of 1/2" plywood under the RH front wheel and 1/4" under the RH rear wheel or I get false readings.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 02-24-2009, 02:45 PM
Speedway Motors sells an inexpensive liquid level display kit to determine the slant of your floor. Home Depot sells the designer vinyl floor tiles to bring the floors up or down to spec.
Sherwood
Old 02-24-2009, 03:22 PM
armandodiaz's Avatar
Best purchase I ever made:
http://www.sears.com/shc/s/p_10153_12605_00948295000P
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 02-24-2009, 03:45 PM
Less brakes, more gas!
euro911sc's Avatar
Wow, that Sears piece looks great for $29.99!! I'll have to get one and see how cheap I can mfg a jig.
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 02-24-2009, 08:16 PM
avendlerdp's Avatar
My iPhone has an inclinometer application that cost $3.99. Pull off the center cap on the wheel, rest the iPhone on the flat part of the wheel and read the camber.
1972 Porsche 914 Project
2000 BMW M5
1973 Aermacchi 350
Old 02-24-2009, 08:24 PM
Somewhere in the Midwest
MotoSook's Avatar
I bought an aluminum 4' level with a digital level like this Sears unit in it from Amazon Tools for maybe $70. I can't remember the exact $. It's been a while.
I cut the aluminum frame and got it weld for a camber tool. I think I spent about $120 total...but it was cheaper than the Smart Camber...and works the same. I'll post a pic when I get back in the shop later this week.
midnight911's Avatar
It's not a "gauge" but home made for sure
this is how i do it. It's not a gauge but works accurately and reliably...and affordable.
fishing line, fishing weight, masking tape, sponge block, ruler, and excel formula...
1. level the car. 2. tie weight at the end of a fishing line. 3. tape the fish line. 4. put sponge at the fender edge so that the weight and line is free from the wheel/tire, and adjust line so that the line runs center of the wheel. 5. wait for the weight/line to settle. 6. measure the distance from the wheel edge to the line, top and bottom. 7. memo the distances and get the difference. 8. go to your pc, run excel, and do this formula:
=DEGREES(ATAN("the difference you got from measuring"/"wheel width"))
then you'd have the camber angle.
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 02-24-2009, 10:02 PM
Almost Banned Once
sc_rufctr's Avatar
That's a great and simple way to do it... Well done!
By the way I like your wheels
Old 02-24-2009, 11:13 PM
well, my method fails after all. i only hit one out of four spec requirements...
dedicated for 16" Fuchs? no
hands free? no
utilizing an off the shelf digital inclinometer? no
accuracy +- 0.2deg. yes
1998 E36 M3 4dr
2004 Lexus GX470
Old 02-24-2009, 11:24 PM
Thanks midnight911. Just in time too.
Your method/tool met my requirement: CHEAP!!!!!
Anyway, shouldn't you used ArcSine in your measurement? Because the wheel size is the hypotenuse of the triangle? The length of the string would be the adjacent, and the difference in measurement is the opposite side.
anthony
Old 02-25-2009, 08:04 AM
axl911... Nooo, don't do that to me. please. it instantaneously reveals that I slacked off those math classes. I thought i was getting the right figures from the forumla but please do let me know if i'm doing it wrong. My goal was to have equal camber left and right so absolute angle for me was not that important. But i do want to make sure i have someone looking at what i do and make corrections if it's wrong.
what you say is correct.
wheel width = hypotenuse
diff in measure = opposite side
length of string = adjacent side (this value, i think, is not necessary to come up with the value for the angle)
what value was i getting?
1998 E36 M3 4dr
2004 Lexus GX470
Old 02-25-2009, 08:47 AM
porsher
Thanks guys, I have used the plumb bob method and the set square and the laser!!
These methods work well if you measure carefully and if your math skills are sufficient
However, I will be rebuilding my suspension and I will need to make several measurements while making adjustments, hence the hands free no-calc requirement.
So I need some clever self-supporting bracketry ideas.
Old 02-25-2009, 09:32 AM
I didn't meant to make you look bad....your idea is the best. Mine involved straight edge, right angle, level, etc. which turned out didn't work as well.
Anyway, looking at the math (they drilled this into me when I was younger),
sine = opposite/hypotenuse --> measured diff / wheel width
tan = opposite/adjacent --> measured diff / string length
Using tangent would work, but you need to measure the length of string from edge of wheel to edge. But it's another thing to measure and introduces error.
To answer what values you are getting when using arctan ( measured diff / wheel wheel width). You are getting a slightly smaller camber angle than what you are supposed to get. Because the the wheel width, being the hypotenuse, is always > than the string length. But when you compare side to side, it is okay because in reality, you're just comparing the measured difference.
I ran out to the garage and used your method last night using a piece of thread and a heavy socket. I knew my side to side camber is almost the same since the difference between is very small. The calculator subsequently proved this.
anthony
Old 02-25-2009, 09:47 AM
Oh and another caution using levels with the bubble, make sure the level itself is right. I used a cheapie level /w bubble to measure camber first. It told me I have positive camber!!!! So I got another level and compared the two, and the bubbles pointed in opposite directions. Such is the life when you buy stuff from Harbor Freight.
The string method is good and pretty much fool proof, unless gravity is slanted where you live.
Old 02-25-2009, 10:02 AM
avendlerdp's Avatar
Pardon the sideways photo but here is an iPod Touch running "Tilt Meter" checking the camber on my wife's VeeDub. iPod touch costs $200 but you can use it to play all your music and video too. "Tilt Meter" application costs $4.00. It also reads in radian and percent of slope in case you ever need that. It also can be zeroed out to account for an un-level floor.
Not hands free but it sure is instant and bizarrely accurate.
2000 BMW M5
1973 Aermacchi 350
Old 02-25-2009, 10:07 AM
Clever but how do you check caster with that string invention? Rob
Old 02-25-2009, 10:10 AM
Yes it runs
tsiegwart's Avatar
Send a message via AIM to tsiegwart
86.9 degrees?
So the the camber is -3.1? That's alot. Is the i-phone measuring accurately?
Here's a link to mine.
http://targa.shutterfly.com/267
It's pretty low tech, but close enough for home.
No camber gauge will measure toe in, a different tool needs to be built for that.
Todd, Minneapolis
1987 Targa
TargaBlog http://tsiegwart.wordpress.com/
32C #4
Old 02-25-2009, 10:39 AM
Zeke's Avatar
This is from my 914 race car days. It's from the design de jour circa 2002. I probably can't remember how to use it. But, the principle was to use 32 TPI machine screws, one fixed and one loose. Each turn therefore was 1/32nd" from dead plumb. On this model, the screws are 16" apart for a 15" wheel.
Given the diameter of your wheel, a little trig on a scientific calculator would give you the degrees from plumb. Remember that the car has to be on level ground and at ride height with driver. One of you math guys can provide the formula.
Total cost for this is pretty cheap and you can check the car for level with the same device. Close enough.
Old 02-25-2009, 10:40 AM
Zeke's Avatar
BTW, there was (or is) a way to determine castor if you can get your camber numbers at full lock left and right and know the total amount of degrees of the steering. Too complicated for me.
Old 02-25-2009, 10:45 AM
