mrbeasley's Avatar
Belt deflection
Ninty nine percent of you guys know this probably so this is for the one percent that don't.I recently had my alternator rebuilt.In the process of pre chat paying I asked about belt play.Belt deflection should just be considered step one for proper belt adjustment.The fellow recommends also running the car for about 2 minutes after placement of the belt,then shutting the car off and very carefully(BECAUSE YOU CAN BURN YOURSELF)touching the pulley,if it's very hot chances are your belt is to loose and is slipping and needs adjustment.
Old 04-07-2010, 10:13 PM
docrodg's Avatar
sounds like a good way to burn yourself. Deflection needs to be checked but touching the pulley to see if it is hot sound like a bit of bs IMO. How hot indicates a loose belt vs heat from engine and correct tension heat caused by friction of the belt?
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 04-08-2010, 06:39 AM
deathpunk dan's Avatar
If it's too loose, the light will come on right?
Sepia brown 1971 911T.
Old 04-08-2010, 06:52 AM
Hi
Targa Me's Avatar
Here's how I check belt tension:
Once the belt is mounted; at the half way point between pulleys, twist the belt; it should be only able to twist a 1/4 way, if it twist more than that its too loose; if it twist less, its too tight.
Old 04-08-2010, 06:56 AM
Make Bruins Great Again
Por_sha911's Avatar
For the light to come on it has to be severely loose. It can maladjusted but gripping just enough to keep the alternator turning. Don't wait for the light to come on, check the tension.
Joe
Old 04-08-2010, 07:20 AM
mrbeasley's Avatar
One molecule short of movement
I agree with you Docrodg it is a good way to burn yourself if your not careful.It takes a lot to warm these engines up.It's also possible I interpreted what he recommended incorrectly.There was a "fan belt" mentioned in the short instructional,I'm pretty sure of that.I will be reinstalling my alternator in the next few days and I'll give it a shot.He warned me several times about the potential danger of burning oneself so I will use caution.Regards and thanks for the input it's appreciated..
Peter
Old 04-08-2010, 10:28 AM
Green Skull 006
Jim Garfield's Avatar
Not necessarily, I thought that my alternator bearings were going because I was hearing what sounded like rattling bearings at idle. The belt had just stretched since I last checked it, and after fooling around with the shims to get the proper deflection, the noise disappeared. I guess I have to take back my curses about the damn French alternator.
S Reg 823 R Gruppe 246
1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha"
"It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field.
Old 04-08-2010, 03:52 PM
80-911SC's Avatar
if to loose belt falls off
if to tight belt shines and will break
if just right has a the correct deflection in the belt (how much and how to push is disputed)
also looking at it while running you can see if TO loose or TO tight
Old 04-08-2010, 07:07 PM
mrbeasley's Avatar
Correct belt deflection running test
Hi. As always I don't know what I'd do without all the great input given me here on Pelican.I was just curious how you could judge a belt was on properly by watching it run..curious
Regards, peter
Old 04-08-2010, 08:19 PM
80-911SC's Avatar
if its loose it will have a distinct wobble(best descriptive) in the belt, kind of a fluter if you will
pull all shims from inside your pully and try it, you will see it
Old 04-08-2010, 09:35 PM
mrbeasley's Avatar
Hi
Cool I'll try it out
Peter
Old 04-08-2010, 10:23 PM
mrbeasley's Avatar
Belt deflection
Thanks for the tip.I will check for any abnormality along the belt when its in work mode.
Regards, peter
Old 04-08-2010, 10:27 PM
in the 1/4 turn method. i assume you mean 90 degrees when you turn the belt.
ken
87 targa
Old 04-09-2010, 12:16 PM
dshepp806's Avatar
Belt deflection is 5 MM.
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-09-2010, 02:49 PM
Tags
3.2 carrera , fan belt deflection
