Removing rear seat belts
Do the rear set belt bolts just bolt into threads in the "wall"? I had a b*#$h of a time getting the passenger rear belt un-bolted. Went with the notch\punch\hammer method and got it loose. Now it seems completely loose, but won't pull out. Almost like there's a nut on the back that is spining along with the bolt, but I'd be very surprised if this were the case.
Todd
'81 SC |
Mine just threaded into the boss in the tub wall.
In the wheel wells, you can see the threads of the bolts sticking out a few threads. I would presume you can see the inner ones also, if you can get under the car well enough to see. Maybe they are just gummed up from sealant/undercoating. Get under the car, locate the bolt threads and spray some solvent or pentrating oil to loosen them.
