-   -   Quick dipstick question (http://forums.pelicanparts.com/porsche-911-technical-forum/460356-quick-dipstick-question.html)
72T 03-02-2009 05:57 AM
I'm trying to get a sense of oil usage, and how much to add without overfilling. I've got the stock dipstick in th '72, which shows high and low lines about three inches apart. I can't find anything in my manuels concerning adding and how much equals rising level. Is it just a matter of: warm the engine, check, add, check, add, etc. until you get there? When filling, is it OK to go to the line, or do you need to let it circulate a bit and re-read? Sorry for the noob question, just want to do it right, and learn something.
Rot 911 03-02-2009 06:23 AM
Full is actually mid-point between those two marks. The difference between the two marks is around a quart.
Paulporsche 03-02-2009 06:28 AM
And you are right: do this on level ground, w/ the engine @ 176F and running @ idle. Or if your engine stalls upon opening the oil filler I imagine you could check the level right away after the engine is off.
notmytarga 03-02-2009 08:26 AM
The 1972 is obviously different because of the position of the oil filler on the fender.
Oil level in the tank will change with idle speed and engine temp. It is not reasonable to assume that the level will not change quickly after the engine is off - because it does, significantly. to check the level - the engine is warm and idleing at 1200 ish, so there is no need for delay in reading the level.
There is a original decal in my 1975 engine bay that says that the difference between the top and bottom marks (about 3 inches) represent 2.5 liters - which are very similar in size to quarts. Since the oil level sender is the same - this calibration should carry.
Answer - Oil volume to take the oil level from the bottom to top mark is approx 2.5 Quarts.
Hope this helps.
72T 03-02-2009 09:00 AM
Thanks all. 2.5 quarts or 1 quart difference? I guess I'll just go slow and see what happens. Also, when I checked over the weekend, the oil temp was at or above 210 degrees, would that make it read lower, assuming that temperature can make a difference?
tharbert 03-02-2009 09:13 AM
In my 72, I can't get a good "dip" on the stick as oil spashes over fingers and stick before I can get it out. I wonder if some diverter that redirects the scanvenged oil is out of place. I have been using the gauge to tell me when it starts getting low. The oil level gauge always shows "low" until the temp gauge lifts off the peg then gradually levitates to a true indication of the level. That is, true to the eyes as I look down into the tank.
S2GART 03-02-2009 09:52 AM
Kurt V, if mid way beween points is full, then what is the upper mark for?
chrisgo17 03-02-2009 10:43 AM
I have wondered about the upper mark for 25 years. I was always told in the middle but no more. Though I do not go by the Gauge, it puts it at 7 with 8 being in the red.
Rot 911 03-02-2009 10:48 AM
Hell if I know. Funny German thinking. My BMW also has a dipstick with two marks and full is right in the middle.
72T 03-02-2009 10:48 AM
My mechanic recently told me "upper line, no more", maybe that is the drop dead line? It seems like there would be a line for "proper fill" somewhere. "In the middle" seems un-German.
tobluforu 03-02-2009 10:54 AM
I just go by the gauge in the car. ;)
72T 03-02-2009 11:02 AM
A great idea, that dash indicator. Too bad mine's broken...!
S2GART 03-02-2009 12:06 PM
Don't rely on that oil level guage. Mine fluxuates too much. Alot of times with the engine running it indicates in the red, when I know full well there is pleanty of oil. There is nothing more accurate than an oil mark on a dip stick.
To help me guage any oil usage, I actually made an additional mark in the middle of the 2 factory marks.
moneymanager 03-02-2009 12:45 PM
You guys have too much time on your hands. Level ground, warmed up, in the middle of the two marks. That's all anyone needs to know.
Paulporsche 03-02-2009 01:41 PM
moneymanager,
And add: "engine idling"
I'll go w/ notmytarga for now just to be on the safe side. What he has said is the factory procdure. I was hoping that the level wouldn't change in a few seconds, or that the mark on the stick would still be @ its previous, running level for a few seconds for those whose engines stall, but I have to admit I won't be able to verify this for a few weeks.
daepp 03-02-2009 02:49 PM
My 72 has so much splash it's difficult - but still possible - to read the stick. I keep it in the middle.
As for the gauge inside, I do rely on it. It tells me - in general - the level of my oil in the tank. I would guess that they are not comparable between cars, but if you get used to yours, you just about don't need the dipstick. With the gauge, it is very obvious when I am getting 1 to 1.5 quarts low, and similarly obvious when I've added a quart.
As for the inop gauge, check the leads where they attach to the sender at the tank. Mine fell off once.
moneymanager 03-02-2009 02:50 PM
Excellent addition, and very useful for those who were raised on Buicks.
pwd72s 03-02-2009 03:48 PM
I'd add that it's 8.5 quarts for an oil change on a '72...not the 10 quarts of other years. The forward oil tank has less capacity than the rearward mounted ones.
daepp 03-02-2009 05:13 PM
Paul - even on the S with the front oil cooler?
pwd72s 03-02-2009 06:31 PM
Front cooler or not...8 1/2 quarts per change. You see, the "dirty" oil stays in the lines and cooler when oil is changed. That's with the factory set up. IIRC, elephant racing lines now have a set up where you can use compressed air to clear all the oil...if so, that should equal about a quart.
