(the shotguns)
berettafan's Avatar
Best way to support rear of car for removing spring plates?
Sould i set the jackstands under the torsion bar tube (inboard of the seam) or at the rear corners of the tub?
Old 03-08-2009, 08:07 PM
Gordo2's Avatar
Same
Berettafan,
I'm just starting into a major suspension project, removing my spring plates in the process.
I don't think you can remove the spring plates with a jack stand on the torsion bar tube.
If you do a search for "lift points" you will come up with a bunch of info on lifting and putting your car on jack stands.
Good luck, Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 03-08-2009, 09:20 PM
OZCarrera3's Avatar
This will probably get me flamed, but I raised the car in the normal manner, then placed a broad (4" plus) wide timber board that runs the full-width of the car just behind the firewall I supported the beam each side with bricks stacked 2x2 to the required height (about 4 bricks). The timber board spreads the load so that you don't dent the underbody. Has worked fine for me.
Sheldon
'92 964 Carrera 2 (Manual)
'07 BMW 335i
'76 911 Carrera 3.0 (Gone, but not forgotten)
"Give me ambiguity or give me something else!"
Old 03-08-2009, 09:32 PM
HarryD's Avatar
berettafan ,
When I refreshed my suspension I supported the rear with jack stands on the torsion bar tubes. That way they were out of the way when I pulled the springplates.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-08-2009, 10:34 PM
midnight911's Avatar
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 03-09-2009, 12:18 AM
