2.7 questions
what are the over size p&c sizes that fit into a 2.7 case without machine work
Charles at LN Engineering is the only one that I know who sells custom size Nickie's from 91mm to 93.5mm cylinder sets that slip into the 2.7 7R case. JE will make the pistons.
I'm running 93mm with a 66mm crank in a 2.7 7R case. All good so far. |
| All times are GMT -8. The time now is 07:57 PM. |
