Doh! No start after cat replacement.
In order to shave a few more pounds, I pulled the cat off of my 3.2 and replaced it with a "test pipe". Now it won't start, and the fuse closest to the driver is blown. After replacing it, the car started but quit almost immediately and blew the new fuse. (What's the chances of two bad fuses? [My old college electronics teacher loved that joke. :rolleyes:]) Anyway, the only thing I can think of is the O2 sensor harness my be pinched, I'll have to look at it tomorrow. Could that cause this condition.
BTW, it's an 85 3.2 in a 76 911S, and I've had this combination for almost 20 years. TIA |
Since the only thing you could have messed with in the change from the cat to a test pipe would be the 02 Sensor, process of elimination would make me believe this has to be it. Either a pinched or cut wire, bad connection or somehow debris on the tip of the sensor.....But, I thought all of these things would just make the engine run terrible, not blow a fuse....If there is a wire shorting out from the sensor, I guess this could cause a surge and result in a blow fuse....Should be easy to identify by taking a close look at the sensor wire and connection.
I am confused as to which fuse blew.
The OXS heater is unfused and comes directly from the battery through the DME relay. I bet the DME relay will serve as the fuse if that is shorted. |
The problem is the O2 sensor itself. The wires are frayed right where they go into the sensor, and they were shorting out. It runs without the O2 connected, so I assume it will just run in open loop with no O2 sensor connected. Ouch! $160 for a new one. |
You can buy a generic Bosch (or other brand) replacement one for $50. You will have to solder your connector onto the generic replacement. I do not think our host sells the generic replacements. It's the same O2 sensor as the $150 one, it just doesn't come with a connector attached.
Thanks for saving me a hundred bux! |
Really? I've never heard of such a thing. Are you a wrench? |
Was at one time I am an Instructor for Navistar. But I was also a Instructor for Bosch for there BSC's
The install of that generic one is actually really easy. You just need a small pocket scale, side cutters, and a little time.
Oh, I was just talking about having a little ruler handy - the install instructions tell you to cut the OEM wire a certain number of inches away from the sensor, so it's handy to have a pocket ruler around to do the measurement. After you cut off the old sensor, it's a matter of refitting the heat sheathing, and all the wire connections happen with some twist-on and snap-in connectors, not through soldering.
This all assumes it's the same Bosch unit that I installed - judging from the pic of the generic Universal connector, it does look like the same. Good luck! |
Thanks for the info. |
Very nice to hear Pelican stocks the generic replacements.
The "air through the wire" argument seems beyond silly to me. FWIW, I soldered, heat shrunk tubed, and self-fusing silicone rubber taped mine, and it's been working just fine. |
| All times are GMT -8. The time now is 06:58 PM. |
