hey kevin you can try this set up.http://forums.pelicanparts.com/uploa...1236862747.jpg
That would work. It's basically a backup for the idiot light... :cool:
I luv this forum!!!
There is always a solution/suggestion to help each other regardless of the issue... |
Thanks Kodioneill and Ronin.
I will look into both options. I have made a habit of looking at the gauges but according to a lot of people (including Wayne) considerable damage can happen within minutes of losing the belt. Also I understand that the head and cylinder temperature can rise a lot faster than the engine oil temperature (and gauge reading). Seems to me that the small cost of either option would be worth investing in. Perhaps I am too conservative. 1977 911S coupe 1969 TR6 British Columbia |
a while back i remember some people were selling these little buzzers for the cars that did not buzz when you left the lights on when you shut off the ignition - kind of a battery drain warning. these were cheap, maybe you can find one of these.
georgie |
I suggest getting one of those electronic dog collars that send an electrical jolt to your neck muscles - rewire it to be triggered by a temperature exceedance and you are ALL SET.
| All times are GMT -8. The time now is 01:38 PM. |
