grateful user
bearings
my poly bronze front bearings came in today, (taking off the new hard plastic ones) started to read threads so as not to run into anything unforeseeable, and noticed that elephant sells the new and improved outer shell that the bearing presses into. are they necessary? can i use my old ones? thanks, don
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
sudo apt-get purge 930
You can use the old ones if you are sure the body mounts are good. The kit helps align the front and rear bushings due to damage of the body or imperfections when the car was built. I put them in as insurance. Based on what I've seen and read most people do the same.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
AutoBahned
when to use is addressed in the Elph. pdf sheet on website
in essence - can try w/o and see if that works if you don't mind delays (say, if you do need them) can buy if you are relatively price-insensitive w.r.to delay issues if pan repaired/replaced; care ever crashed ---> likely needed be SURE to inspect the crevices in the front body reinforced mounting area -- it is a rust trap -- see my yet another boring Rguppe car thread for pics. Good Luck |
grateful user
car has never even had a fender bender, and was recently stripped and media blasted, will try the old ones first. 200.00 bucks?
