Mo money = mo parts
Master Cylinder Brake Light Switch Narrow Pole
I am in the process of replacing my master cylinder on my '86. The new replacement sourced from our host came with the three poles (spades) while my car is equipped for two. After some searching, I ordered a two, two pole switches from my local dealer. I was fully expecting to receive two wide pole switches, but when the switches showed up they were the same as my car.
I just wanted to share this since I was under the impression that the two narrow pole switches were NLA and that I would need to do some minor modifications the make the wide pole work.
Pictured is the new three pole switch from the master cylinder and the new sourced two pole, plus the old two pole switch from my old master cylinder. Second picture is the part number on the bag.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 03-14-2009, 07:11 AM
burgermeister's Avatar
Interesting - thanks!
I could not find the appropriate 2 pole switches when I had the same issue, but I readily admit to not looking very hard ...
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 03-14-2009, 09:58 AM
