What the $%^ does this switch do?
I have an 86 Cabriolet Carrera convertable. On the center console there is what appears to be a defrost switch slightly above and next to the A/C knobs. What is it for?
Gordon |
wing mirror heating
I think it is a rear defrost switch. Although I guess your Cabrio doesn't have a rear defrost, maybe they used the same console for coupes & Cabrios, or maybe some PO put a coupe console in your Cabrio?
Ok
Thanks. I need to open the console to get at the A/C motor speed switch anyway. I'll check the wing mirror wiring to see if that's it!
Gordon |
Johnson Rod activator
So when is the button actually "on". It lights up when it is popped out but that seems counter-intuitive.
Pull it out to turn on. If your parking/headlights are on it should glow a bit when off, and light up more when you pull it out to turn it on.
| All times are GMT -8. The time now is 04:05 PM. |
