Weber Main Jet Stuck
I have a main jet stuck in my 46mm PMO's . The main jet carrier broke off as I tried to remove it. I removed the broken carrier but the main jet is frozen inside. I have soaked it in everything to no avail. Of course I have been very careful not to damage the jet or carb, prob too careful. Any suggestions, Thanks
Old 02-25-2009, 03:01 PM
so the jet is still in the carb with the broken piece or out of the carb in the broken piece?
206 637 4071
Old 02-25-2009, 03:05 PM
I removed the broken carrier from the carb but the jet is still inside carb. Maybe I better post a picture thanks
Old 02-25-2009, 03:14 PM
the brass can bind in the pot metal. i went through this a while back. drilled the jet out as much as possible and used a straight flute easyout. lube it too. a spiral easyout can expand the piece and cause more binding as it's twisted. if it resists, maybe heat it in the oven.
206 637 4071
Old 02-26-2009, 05:39 AM
Thanks, I'm about ready for the heating in oven trick,,,God last time I put Carbs in oven was in the 60's Thanks for you advice
Old 02-28-2009, 04:14 PM
Thanks John,,,Mission Accomplished
Old 03-10-2009, 07:36 PM
