-   -   How to install RS carpet and make it look good? (http://forums.pelicanparts.com/porsche-911-technical-forum/462108-how-install-rs-carpet-make-look-good.html)
RWebb 03-11-2009 10:58 AM
camping mat (sleeping pad) -- used to be a foam called ensolite
you want to try and find the kind that is pretty flexible
note that there are foams that are somewhat fire retardent or 'safe' - not sure which
to really save wt., you will need to use FG or CF panels for steel on the bumper, deck lid, & etc.
one approach:
http://forums.pelicanparts.com/showthread.php?s=&threadid=273740&highlight=yet+an other+rgruppe+boring
of course, there is no need to add excess wt. back there in the cabin!
gtc 03-11-2009 10:58 AM
Looking at carpet pads right now, some have antimicrobial additives and moisture barriers. This sounds ideal for the rear seat area, which is known to collect water. Plus it's lightweight and adhesive-backed.
RWebb 03-11-2009 11:02 AM
Originally Posted by porschenut (Post 4536927)
... Just filling up the gas tank adds 150 lbs. to the car, so it's hard to quibble over a couple of lbs. here and there.
I've done a number of searches but couldn't find the answer to my specific question, but I'm convinced at this point that I need to apply some type of underlayment to provide a relatively flat base for the carpet. When I call Appbiz about ordering the carpet, I'll ask Bob what he recommends.
- you have a 25 gal. tank?
- No one has discovered the definitive material for what you want yet.
I would look at the general aviation community for info...
also - it would be fun to find out what is being used in new Lotus (Lotusi?), the Txx Lotus based all elec. sports car, Porsche & Fcars. Surely, they have come up with something groovey.
an aerogel would be best, but AFAIK you will have to scavenge that from NASA, Lockhead, etc.
willtel 03-11-2009 11:22 AM
one approach:
This is a good source for ensolite foam. I don't think a few sq yards would weigh more than a pound and it should help smooth off the high spots. Cheap too.
http://www.raamaudio.com/cgi-bin/index.cgi?p=pr
http://www.raamaudio.com/images/howt...solitedoor.jpg
martin_gibson 03-11-2009 01:42 PM
Originally Posted by pdqcarrera (Post 4536642)
Martin, did you weight all that Dynamat by any chance to see what it's contributing? Personally if I were to do it all over again I'd do it your way. IMHO the extra few pounds is impossible to notice in a 2500 lb car anyway and the esthetics for me is still important. My RS carpet on the bare metal ain't pretty.
I used a 3.34m2 (36 ft2) Dynamat Xtreme Bulk Pak @ 2.2kg/m2 = 7.4kg total - although I have no idea how much the existing Porsche 'tar' weighed before I replaced it with the Dynamat.
Martin
martin_gibson 03-11-2009 01:51 PM
Originally Posted by RWebb (Post 4536881)
sacrilege ?? not sure why you say that, but combining the heavy asphaltic Dynamat with a light wt. RS carpet can be nothing more than cosmetic benefit. Not clear to me how much wt. the RS carpet saves vs. regular sliverknit, etc. anyway... a search before purchase & installation will find you some better solutions...
Coz I've received plenty of negative responses from the 'lightweight' brigade when I installed the Dynamat in my 911 however by having a little less load on my son's ears my wife is a little happier, therefore I get to keep the Porsche so I'm happy too :)
Martin
RWebb 03-11-2009 02:51 PM
sure - we all have somewhat different goals for our cars
and certainly not damaging an infant's sensitive hearing is a very very high priority
but my point is that RS carpet over Dynamat is not a light wt. solution.
martin_gibson 03-11-2009 03:05 PM
100% agreed.
Zeke 03-11-2009 04:24 PM
Originally Posted by Kroggers (Post 4536667)
Anyone know how the factory did it?
I can't say for sure but I think steamed molds (like doing a hat). Anyway, steam works. Heat works. Carpet does not like to behave in cold weather.
Twinny 03-11-2009 04:42 PM
I''ve got this to do and having done a few English sports cars before (Healey's & MG's) I'm putting a layer of 6mm felt down first with spray on carpet adhesive. Not too thick or heavy and gives you a nice even surface to work to.
http://www.woolies-trim.co.uk/p-986-felt.aspx
You must have companies supplying this stuff in the States.
RWebb 03-11-2009 04:47 PM
I wonder if a portable steamer would work/help?
Someone posted a 'steam cleaner' for cheap a while back...
RRico 03-11-2009 04:53 PM
If anyone needs the RS carpet installation guide I can email you a copy in PDF format.
It is a pictorial guide from Appbiz. PM me.
sc_rufctr 03-11-2009 04:54 PM
Martin
Martin
I'm considering Dynamat for my car. I have permanent tinnitus (ringing in the ears). The idea of putting Dynamat in my car is to reduce the cabin noise... The exhaust note of my car seems to exasperate my problem. I would gladly sacrifice a few pounds so I can drive my car in comfort.
The question is does it really make a difference? Is your car much quieter with Dynamat?
don911 03-11-2009 05:25 PM
In my case (first picture), the smooth carpet is due to the layer of Thermotech FR that I put under the carpet. I cut sections of the thermotech to fit. The carpet is Appbiz plush. Even with some sound deadening and carpet, it was still a good weight savings.
911pcars 03-11-2009 06:15 PM
Originally Posted by sc_rufctr (Post 4537792)
Martin
The question is does it really make a difference? Is your car mush quieter with Dynamat?
As per other installs, Dynamat isn't the only noise-abatement solution. Check the archives.
Sherwood
Buckterrier 03-11-2009 06:22 PM
What about a plan old steam iron? I'd like to do this project next winter, great thread.
sc_rufctr 03-11-2009 06:24 PM
Sherwood
Thanks for the reply but another reason for using Dynamat is because you could glue the carpet directly to it. Similar to the way the factory did it originally.
I would think that any closed cell foam would work but how do you secure the carpet to the foam neatly?
Noel 03-11-2009 06:57 PM
I'm about to do this too so I want to subscribe to this thread. I think in the AppBiz directions it says something about using a thin synthetic pad that you can get at Home Depot as a base, which will help to iliminate the bumps.
porschenut 03-11-2009 08:19 PM
I would think as long as the foam is applied smoothly, a spray adhesive would do a fine job of adhering the carpet backing to the foam. If I end up going with ensolite or something similar, that is what I'll try first.
Don911, beautiful job on the interior! Is the thermotech FR heavy?
RWebb 03-11-2009 09:32 PM
there is a thread where people discuss which 3M spray adhesive to use -- most seem to like the 3M
of course, then there's Swepco....
