-   -   How to install RS carpet and make it look good? (http://forums.pelicanparts.com/porsche-911-technical-forum/462108-how-install-rs-carpet-make-look-good.html)
Stephen-911SC 04-05-2013 07:52 PM
Digging up an old thread because I'm interested to hear advice to 1-ev.com's question posed above, re: do you bend or cut the deck tips. Just ordered the appbiz set today.
appbiz 04-05-2013 10:07 PM
The tabs...
Bob at Appbiz here. Rather than removing the tabs on an early 911/912 you can fasten a 2" or so wide piece of lumber there that is even with the top of the tabs and screw it to the tabs with woodscrews. That way you have not changed the structure and you or a subsequent owner could take a step backwards...
Thoughts?
Bob
Stephen-911SC 04-05-2013 11:04 PM
Now that I have the factory sound pad pulled out and realized that I don't have tabs to worry about ('83 SC) and based on your answer, Bob, perhaps I should ask a more basic question. I'm assuming those tabs are not present on SCs/Carreras?
appbiz 04-05-2013 11:46 PM
No the tabs we only present on the early cars, 1965 to 1969ish. The cars with tabs had a metal crossbar on the top of the parcel shelf.
Bob
wayner 04-06-2013 04:18 AM
Good thread
1-ev.com 04-08-2013 07:37 AM
Bob, do you have any pics of it installed? Thank you, -Y.
Thoughts?
Bob
appbiz 04-08-2013 08:21 AM
RS Carpet set installed
Here are some misc pics of RS Carpet installations
http://forums.pelicanparts.com/uploa...1365434292.jpg
http://forums.pelicanparts.com/uploa...1365434331.jpg
http://forums.pelicanparts.com/uploa...1365434375.jpg
Bob
1-ev.com 04-08-2013 08:27 AM
Thank you Bob, great pics :D.
Do you have any with 2" wood across the tips?
Thank you.
appbiz 04-08-2013 08:39 AM
Sorry no, but it does not need to be 2" just a full lenght wood strip screwed the the tabs. then drape the rear deck piece over it. just feel this is a better way than grinding off the tabs as you are always able to take a ste backwards.
Bob
Matt Monson 04-08-2013 10:31 AM
Thanks for the bump. I've got a carpet kit sitting here waiting for me to finish the rollbar install and get on to the carpet. Saves me some searching later on. Subscribed...
Matt7127 04-08-2013 11:04 AM
I'm in the process of installing an RS carpet in my 82 and was wondering what other have used for glue or adhesive to secure the carpet. I've dynomated a good portion of the rear seat area so the carpet will be glued down to the dynomat. Has anyone used Weldwood, it's a heavy duty contact cement?
wayner 04-08-2013 11:39 AM
I'm wondering about double sided tape for easier replacement some years later when the time comes?
Thoughts?
RWebb 04-08-2013 01:55 PM
a guy posted re a non-toxic glue a while back
Chuck.H 04-08-2013 02:18 PM
The Weldwood is great - When I did mine a few months ago, I used a combination of the spray 3M adhesive (777 I think) and the Weldwood. I covered the whole carpet with the spray, and then used the Weldwood where I needed more stick, like in corners or to hold tabs down or where I needed to stretch into place.
Chuck.H
'89 TurboLookTarga, 349k miles
RWebb 04-08-2013 03:07 PM
it's full of toluene, isn't it??
tirwin 04-08-2013 03:34 PM
I recently did RS carpets in my '83. Used 3M 77 for the carpet and Weldwood for the vinyl trim replacement. I did Damplifier plus a layer of CCF and then a layer of MLV on top of that everywhere but the back seat. I left the factory pad and covered it with CCF. Deleted the rear parcel shelf and the back seats. I kept the side panels under the quarter windows. Deleted the center console too.
Ayles 04-25-2013 08:04 PM
How many yards(and thickness) of closed cell foam did you end up using and how many sheets of damplifier?
I am about 2/3 done stripping the rear area of old adhesive and insulation... so looking forward to next steps!
Thanks!
Ayles
tirwin 04-25-2013 09:36 PM
Someone else asked me that recently. The CCF was on a roll that was 60" wide if I remember correctly. I want to say I bought 10'. I bought more Damplifier than I needed. I have several sheets left. They're about 12"x24" each. I'll make you a deal on what's left. Send me a PM if you're interested. The MLV I only put in the floor pan. I think it came on a roll too. I bought 5 or 6 feet of that. All the invoices are in a stack in the garage. I'll double check tomorrow.
appbiz 04-26-2013 08:36 AM
Bob at Appbiz here, you might want to omit the insulation in areas where water can pool. especially in pre galvinzed cars (Mid 70's and prior....
fred cook 04-26-2013 11:15 AM
RS carpet
When I did the interior of my SC coupe, I also put down a layer of the Dynamat sound deadener. In the seat bottom area where it is so curved, I cut small pieces that would only have to bend in one direction to avoid bulges and wrinkles. It took a while, and I wound up having to order a bit more of the Dynamat inorder to cover the entire floor from rear window to front firewall. Be sure to buy one of the tools with the wood roller wheel to help smooth out the Dynamat as you put it into place. I bought two, a large one and a much small one for tight places. Once the mat was down, I layed out the carpet pieces in the driveway to make certain that I knew which pieces went where and in what order should they be installed. I cut out a lightweight piece of particle board to go in the area below the rear window and glued the carpet piece to the board. Now, should I wish to do so, I can take out a couple of 6mm screws and 3 carpet screws and remove that entire piece. The other pieces were glued in place per the instructions. Other than being a bit hard on the back and knees, this is not a particularly difficult job. Just spend enough time up front to know just what you need to do and the correct order.
Ayles 04-29-2013 06:14 PM
Found some closed cell foam locally. Wondering if this is a similar material to what is being used by other members.
Neoprene Closed Cell Foam and Specialty Foam : Water Resistant Fabric : Seattlefabrics.com
or this stuff
http://www.onlinefabricstore.net/specialty-stores/automotive-specialty-store/automotive-carpet/automotive-carpet-padding/jute-carpet-padding-20-oz-.htm
Ayles 05-03-2013 06:51 PM
Bump on this, I was hoping for some opinions on the materials I am looking at.
It's kind of a tough decision and would love to hear how the different materials are holding up.
I just finished stripping the interior and trying to plan my next moves.
Thanks!!
Ferrino 12-14-2013 04:06 PM
I like the idea of using closed cell foam as a smooth underlay for the carpet. Where could I try find a local supplier, please? Home Despot?
Ayles 12-14-2013 08:05 PM
There is a specialty shop here in Seattle that deals in foam. I bought a couple different sizes to experiment with. I am pretty sure they ship too.
I have the 1/8th landau pad and a sheet of the 1/2" charcoal. Let me know if you need a couple pictures. I am thinking the 1/2 inch might be a little thick to be easy to work with. I will most likely use a combination of the two to smooth things out.
froggert 12-14-2013 08:56 PM
Or possibly an outdoor sporting goods store. I bought some closed cell foam for another application (motorcycle seat) from a kayak supply place.
douglas bray 12-14-2013 09:22 PM
I used grey felt from Pep Boys under my black App-Biz Perlon felt. LOVE IT. Foam just sounds like a stupid idea and I sell millions of dollars a year in closed cell and PE foams.
Ayles 12-14-2013 09:47 PM
Can you share any pics? Im interested and not committed to any single install method. Just want something that is durable and looks good.
718 12-14-2013 10:02 PM
Why?
Foam is commonly used in automotive sound barrier applications. Is felt better somehow?
Ronnie's.930 12-14-2013 10:06 PM
True class = a foam salesman calls the ideas of others' "stupid" without offering an explanation as to why. :rolleyes:
merbesfield 12-15-2013 05:43 AM
McMaster Carr sells many varieties of foam.
javadog 12-15-2013 05:52 AM
Things like felt probably have an indefinite service life. I've found that most foams usually degrade over time. They either get hard, lose their resiliency, crumble, disintegrate... something. It may take 10 or 15 years but they generally crap out in one way or another. Since I'm not in that industry, it's hard to figure out which one may have the best service life. There may be some good ones out there but I've had a lot of problems with others that didn't hold up.
Foams are often lighter, though.
JR
sithot 08-16-2019 06:21 AM
Originally Posted by stormmaster (Post 5147173)
Buckterrier mentioned my interior....I think I am going to redo it with some underlayment....not sure I can re-use my carpet or not...if not I will get another set from Apbiz...anyway...here is a shot of the rear with the stock parcel shelf intact.
http://forums.pelicanparts.com/uploa...1264522096.jpg
Anyone have a clue where this carpet kit may have come from. I don't want to change the color of my basic interior which includes blue sport seats and dash.
Thanks!
Tom
hienz 08-17-2019 06:22 PM
Wet the carpet a little then use heat gun and hammer to make it curves
Harpo 08-19-2019 02:47 PM
I just ordered some 3/8 foam from aircraft spruce.
Rodsrsr 08-19-2019 04:06 PM
The foam is the key...
http://forums.pelicanparts.com/uploa...1566255972.jpg
javadog 08-19-2019 04:32 PM
Thanks!
Tom
Did you ask the guy that said the photo was from his car? It sounds to me like he bought it from Applied Business Concepts.
