Axle Orientation
I tried a search, but could not find the answer I'm looking for.
When replacing CV joints (or whatever might cause one to remove the axle) does it matter which end goes in/out? There is a splotch of paint on my axles and I'm wondering if that is a mark for orientation.
I know there's an orientation for the CVs themselves, but not sure about the axle.
Thanks!
1979 911 SC Silver
2002 996 race car
2005 Ford Excursion
Old 04-16-2009, 01:29 PM
SteveinTO's Avatar
If the CV's are identical on each end, I don't think it makes any diff which way you put them. Torsion bars, while they look similar, are another deal altogether.
Old 04-16-2009, 09:52 PM
IROC's Avatar
I've swapped axles around on a 944 in the past. As long as the axle type is the kind with the same CV configuration on both ends, it's fine.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-17-2009, 04:21 AM
Somatic Negative Optimist
Gunter's Avatar
Thumbs up
Thanks!
IMHO it matters.
The axle shaft experiences torque for many years in the same direction and I would keep that same rotation by marking the axles before removing.
Unlike Carrera, SC-CV's can be switched on the shafts (maintaining the same rotation) to get a new running-surface in the races for the balls.
That's what I did when checking the CV's couple years ago.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 04-17-2009, 09:57 AM
That's kind of what I was thinking. Maybe like T bars but not as critical. I took my best guess and put them back on in what I think is the right orientation. I'll let you know if I snap one!
Thanks everyone for replying.
1979 911 SC Silver
2002 996 race car
2005 Ford Excursion
Old 04-17-2009, 10:08 AM
rw7810's Avatar
I agree with Gunter. I was told you can switch them from side to side, but reverse the inside to the outside so the axle itself is still "twisting" in the same direction. I hope that makes sense. You can reverse the CV joints too to change the "wear side". it's Friday and this probably doesn't make any sense.
Robert Williams
70' 911T
Old 04-17-2009, 10:57 AM
