Send a message via ICQ to Kurt B Send a message via Yahoo to Kurt B
Post Gearheads: A 996 transplant?
Has anyone performed on yet on an aircooled 911 chassis? (Ideally, a 930 from any year)
Old 06-05-2001, 06:09 PM
Yargk's Avatar
Post
I don't see a fully water-cooled engine going into a 930 since the only fully water-cooled engines are normally aspirated. However, if it would fit, and if I had infinite amounts of cash, I would put in a 996 turbo engine in which has water-cooled heads. I'm sure once I swapped out the pistons and cylinders for lower compression ones and put in larger turbos, the engine could put out a reliable seven hundred horse with proper engine management. I'll just stick some radiators somewhere. lol, I can only imagine.
Keith
79 930
Old 06-05-2001, 06:28 PM
