RSR style fuel lines
Does anyone re pop the RSR style fuel lines that go from the MFI pump to the injectors? They could be black hard plastic, or steel braided flexable lines. Somebody must have duplicated these.
Old 03-05-2009, 06:16 AM
BoxsterGT's Avatar
Porsche Crest
I have all the fittings, and clear Poly lines. If you prefer I certainly can order black or braided SS.
I can assemble them if you like, but you must specify the lengths.
Everything is from Cohline in Germany.
All the plated pieces are coming thru silver zinc.
If you want yellow zinc I must have them stripped & plated locally.
Len@autosportengineering.com
Old 03-05-2009, 07:01 AM
BoxsterGT's Avatar
Porsche Crest
Here is a photo of the type lines I have in stock.........
I will have the Banjo fittings soon if you need them. Presently I only have straights out of the pump and into the injectors.
Len
Old 03-05-2009, 07:09 AM
BReyes's Avatar
Are the SS braided lines continuous to the tank? I am thinking of doing SS braided to the tank.
Regards,
Bernard
Old 03-05-2009, 02:32 PM
Bernard, no the lines go from the MFI pump to the injectors.
I checked both ebay.de sights,thanks. Looks like a pretty big price differance between the two for the same thing.
I like Boxster GT's set up the best. Banjo bolts give a cleaner look as the lines lay down to give a wider air cleaner choice.
Old 03-06-2009, 05:14 AM
BoxsterGT's Avatar
Porsche Crest
Clear Poly line has come in........
Only have one 20m roll. More to come via a slow boat.
Len
Old 03-13-2009, 07:36 AM
