brads911sc's Avatar
MSD - 83 SC Question
I have an 83 SC with the PermaTune. Switching it out for the MSD 6200 and Blaster Coil... Which Tach adaptor do I need? 8910 or 8910 EIS?
Thanks in Advance
Brad
83 SC
Old 03-12-2009, 06:31 PM
PeteT's Avatar
Brad-I have an sc also and didn't need a tach adapter. Works fine no problem. Good luck
Pete
Old 03-12-2009, 08:24 PM
Also, I recommend you use 8.5 mm Magnocre or equivalent plug wires, and open up the plug gaps per MSD suggestions.
Old 03-12-2009, 08:29 PM
dlagerstrom's Avatar
Me too. '82 with permatune that quit. Replaced with 6200 and high-vibration blaster coil. Tach works great as is.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 03-12-2009, 08:41 PM
brads911sc's Avatar
Great. Thanks.
I have the braided stainless beru wires. will they not be able to handle the MDS?
Old 03-13-2009, 04:11 AM
I think it's not whether the Beru wires will handle the MSD as it is that the Beru connectors are terrible. I went to twin MSDs, twin Blasters and 8.5 Magnecor wires, at the suggestion (demand?) of Steve Weiner, also on an '83 SC (twin-plugged, also by Herr Weiner). Didn't need a tach adapter either.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 03-13-2009, 07:20 AM
Formerly bb80sc
Vipergrün's Avatar
Another cool trick is to use spade connectors (with a bit of dialectic grease) to connect the MSD to the OEM harness connector. No need to splice. No tach adapter needed on my 80SC. Used Magnecor wires, plugs gapped to .045.
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 03-13-2009, 07:56 AM
