opie's Avatar
86 3.2 idle
Has anyone had this problem, When idling my 86 911s idle will surge from normal ilde to about 1300rpm then drop back to normal sometimes it will completly die, it does not matter if it is hot or cold and sometimes it wont do it at all. I took it to a pcar man but of corse he could not get it to do it. Any help would be great.
Old 03-10-2009, 06:21 PM
EMT/TechRescue Instructor
86911cab's Avatar
I had a problem like that. My Idle was just a touch too high. Are you familiar with adjusting the idle speed.
1986 Iris blue 911 Cabriolet
2017 Ram 1500 Night edition
2025 BMW X-5
Old 03-10-2009, 06:45 PM
Make Bruins Great Again
Por_sha911's Avatar
There are numerous possibilities: vacuum leak, bad O2 Sensor, and a host of others. Do a search for "hunting idle" and start with the stuff that's free.
Joe
Old 03-10-2009, 07:03 PM
I sometimes had this with my prior 86. The mixture was the issue with mine. It was set a bit rich. Besides the possibility of the idle being misadjusted, the Idle Stabilization Valve might also be defective. That can be cleaned. Lots of thread on this general and common issue. Can be caused by a few things.
todd
89 Targa
Old 03-10-2009, 07:06 PM
opie's Avatar
I have never adusted the idle and have replaced the O2sensor I am not familiar with the idle stabilizer.
Old 03-11-2009, 03:27 PM
86 Carrera Coupe
janz's Avatar
Location: Holyoke, Massachusetts (western end of state)
I had a surge in the idle more often than not. O2 sensor, replaced the oil filler cap and gasket and really helped out but still did it every once and a while. Installed Steve Wong chip and followed his instructions to adjust idle (can be found on his web site). Haven't had a problem since even with AC running.
Old 03-11-2009, 06:19 PM
Banned
idle surge
I have 86 carrera and found te right side intake manifold gaskets leaking spray carb cleaner at the bases for the intake runners to the heads and see if idle goes up if so the gaskets are leaking once removed you could see the gasket material was all wet.
Regards,Lee
Old 03-11-2009, 06:59 PM
Subscribe... Interested in what turns out to be the problem and solution.
Black 1985 Carrera ~ Whale Tail - Gone but not forgotten
2013 Boxster - Wifey Car
1969 Karmann Ghia - Next in line for restoration
"Driving in its most beautiful form"
Old 03-12-2009, 11:08 PM
