Talewinds's Avatar
Aftermarket Stainless Door Sills, Did Yours Require Modification?
So I bought the stainless steel Ebay door sills that people seem very happy with. My dilemma, the sills they sent are made to match the correct shape of a 911, and have a 90 degree lip bent into them, therefore the sills are laser straight, however, the door sills on my 911 are NOT laser straight! On both sides of the car the door sills taper inward slightly as the sill proceeds towards the rear of the car.
Were you able to expose the tape adhesive on your sills and stick them down and they mated up perfectly to your door sills?
88' Carrera, Black/Black/Black, "Murdered Out" OEM.
06' BMW 'M' Roadster (Wife's car and WAY faster than mine)
Old 03-13-2009, 11:59 AM
si Banker's Avatar
Bad News
I tried to make some sill plates and learned that there is a slight curve to the door sill. If there is a ninety degree bend at the back it will not fit flush. I hope you can return them. By the way my car is a 1987 coupe
1987 911 Coupe
Triumph Trident Track Master
History is the lie we all agree to..........
Old 03-13-2009, 12:25 PM
grateful user
don gilbert's Avatar
sills
the renlines sills from our host have the lip, and fit very nice , 100.00 bucks
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 03-13-2009, 01:10 PM
