steely's Avatar
Oil thermostat re-install
What could be giving me grief, making re-installation of my oil thermostat difficult?
The removal was uneventful, I kept the well and engine surface clean, R&R'ed the oil ring, and put clean oil on a clean thermostat - but she seems to balk, and I don't want to force it.
It is not even going all the way down to the O-ring, and in fact, I have the most problem just getting it started. I can't figure it out!
The t-stat isn't keyed, and the holes/ports are lined up properly.
Could the body be this sensitive to temperature? - garage was cold last nite but stat was out less than hour.
any help'd be appreciated.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 03-14-2009, 03:50 PM
dshepp806's Avatar
I had to apply a bit of pressure to get mine to seat inward...must be that damned new green Viton.....(oiled, BTW)......
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-14-2009, 06:24 PM
steely's Avatar
Thanks Doyle,
the ring is oiled, but I'm having probs with just the first inch!!
I haven't gotten it to go down to the ring yet.
completely unexpected.
Dan
Venetian Blue
Old 03-14-2009, 06:33 PM
steely's Avatar
no foolin' - the sucker is tough to start.
Would light tapping w/a rubber mallet hurt?
It's out in the garage ready to go.
Any ideas?
Dan
Venetian Blue
Old 03-14-2009, 09:18 PM
Band.
You know it only goes in one way, right? Check to see the holes in the top are going to line up with the studs.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 03-15-2009, 06:48 AM
steely's Avatar
Check - one way - holes line up with ports, and mounting holes are aligned with studs. It is literally the FIRST INCH that has me stuck.
It's not like I dropped and warped the thing either - oh bugger.
Dan
Venetian Blue
Old 03-15-2009, 08:12 AM
steely's Avatar
IT'S IN!!
I stuck it in the freezer last nite (oiled and in a clean ziplock bag).
It was exposed to the air for maybe 3 seconds before I got it positioned and it slid right in.
Dan
Venetian Blue
Old 03-15-2009, 08:18 AM
