-   -   Rear sway bar bracket broken, help! (http://forums.pelicanparts.com/porsche-911-technical-forum/463007-rear-sway-bar-bracket-broken-help.html)
bklyn 03-15-2009 01:23 PM
Gents as I was checking around under my 87 911 of course I noticed the pass. side rear sway bar bushing bracket was broken right from the frame. It seems like it rusted away. Is there a bracket that I can purchase? What would be the correct fix? Thanks Lenny:eek:
Joe Bob 03-15-2009 01:28 PM
Common.....Pelican sells a replacment part. I think Elephant Racing has an upgrade....
bklyn 03-15-2009 01:34 PM
Mike is it called a butterfly bracket?
Gunter 03-15-2009 01:38 PM
Lenny:
Do both sides while you're at it with the re-enforced version. (The upgraded brackets are welded to the body)
bklyn 03-15-2009 01:41 PM
Gunter, thanks I also want to make sure I order the correct bracket. Apprec. the help.
Por_sha911 03-15-2009 01:43 PM
The old bracket has to be cut off and a new one welded on. Wevo makes the heavy duty one. Do both sides.
http://forums.pelicanparts.com/uploa...1237149809.jpg
p.s. This a common thing that has been discussed many times. The Search button is your friend.
bklyn 03-15-2009 01:48 PM
Hey Porsha, thats exactly what I needed, perfect guys thanks!
bklyn 03-15-2009 02:47 PM
Gents, just thinking, I am not a welder, Any good suggestions, what do you think someone wouls charge for that?
88-diamondblue 03-15-2009 03:01 PM
Do the Wevo and never do it again. I had both sides welded once and then one side broke again. Put the Wevo on and never will have to do it again.
One tip is when you line up the new brackets to be welded have the car sitting on a lift with the weight on the suspension. First time I did this I lined it up with the car on jack stands. The sway bar touched the trans mount after putting the car on the ground. A welder should be able to do it in 1 to 1 1/2 hours labor. Most time consuming part is grinding the old ones off.
http://forums.pelicanparts.com/uploa...1237154106.jpg
http://forums.pelicanparts.com/uploa...1237154151.jpg
bklyn 03-15-2009 03:05 PM
Mike good pics, I am going to order them today and have a welder do the rest.
Por_sha911 03-15-2009 03:05 PM
Go to a bodyshop guy and he'll do the job for less than $100 labor
sc_rufctr 03-15-2009 03:16 PM
That looks bomb proof... :cool:
bklyn 03-15-2009 03:28 PM
Thats an idea, I have a reliable guy who did my wifes Boxster when she backed into my sons brand new Dodge Ram right in the driveway$$
88-diamondblue 03-15-2009 08:21 PM
The other thing I did after grinding off the old mounts was to use zinc weld through primer to prevent rust. Then hit again after the welding is done. The primer is about $8 a can.
Gordo2 03-15-2009 09:15 PM
Sway bar hitting trans mount
Here's a good thread on installing the Wevo
http://forums.pelicanparts.com/showthread.php?s=&threadid=221342&highlight=wevo+p roduct
88-diamondblue,
Are you saying you didn't have the Wevo RARB mount correctly positioned when with your first mounting? If you did it like Tyson did in the linked thread - assembling the bar to the mount and holding it firmly in place with a jack as you tack up the mount, would that have solved the issue?
Asking because I'm a couple of weeks away from doing the Wevo mount upgrade on my car, and thought I would do it like in Tyson's thread. Not sure how I would weight the suspension as you recommend.
Thanks, Gordo
arrivederci 03-15-2009 09:57 PM
Not sure what kind of clean-up you'll need since yours tore off. But when grinding/cutting the factory ones off, they're not welded on particularly well. There's a bead along the longitudinal seam and then a little done on each side. See the following pictures for what mine looked like after I cut them off along with a blurry installed pic.
It isn't too hard to get it clamped in the right position...the old mount's location was pretty obvious. The sway bar moved smoothly afterward with no binding. Also, I too used weld-thru primer.
<img src="http://lh6.ggpht.com/_WICCR-SC8nk/Sb3bhPQgz3I/AAAAAAAAAvo/8xHLwqa-Drg/s800/IMG_0672.JPG" /></a>
<img src="http://lh6.ggpht.com/_WICCR-SC8nk/Sb3a0UiXcCI/AAAAAAAAAvI/IKnmrouAFOo/s800/IMG_0675.JPG" />
Flieger 03-15-2009 10:04 PM
Is that your 911SC or your early car? I have heard that the WEVO mounts do not fit very well on early 911s. I have a 1971 911S with Weltmeister front and rear sway bars. I just had my passenger side factory sway bar mount break but I have seen photos of early cars with WEVOs where the sway bar hits the ground during hard cornering. I am planning to have the factory mounts repaired and gusseted by a pro Porsche shop.
88-diamondblue 03-15-2009 10:24 PM
Second time around I just put a stack of 2x6's under the tires to allow me to get under the car and get the mounts in the right place and were tack welded into place. I did use a jack to hold it in place, it was I just placed it wrong with the suspension in droop. Same procedure the second time around but could see where the sway was located next to the trans mount with suspension in compression. I then unbolted the sway bars and the welds were finished. The 87-89 used the aluminum trans mount which the sway bars had a bend to go around (correct me if I am wrong) the mount. I moved the mounts about 1/2" from the first time. It was not as easy to see where the others had been.
The guy who helped with this is a magician with metal, the old mounting locations were perfectly smooth after he was done. He even took these off and we reused them. He reground the taper and I could not tell they were anything but first time job.
arrivederci 03-16-2009 06:08 AM
That's my SC but I have them on my '72 as well. The smart racing bars (the arms actually) do look close to the ground on the '72, but I don't think it would hit when on track. Off track could be another story.
I -think- the lack of lower sill trim and the 205/50 R15 tires is what makes it look so low. Moving up to a 55 or 60 series would obviously give the sway bar a little more clearance.
stevef 03-16-2009 08:45 AM
I just did mine yesterday on my 87. Don't know if I needed to but I decided to remove the DME. One of the threads I read suggested it as a good idea. Theoretically with a good grounded welder it shouldn't make a difference but to be sure I did. The welding part was the easy bit. If you have to take it to a shop the cost is in the set up and any other precautions (like DME) etc and getting any oil lines out of the way.
radar54321 05-16-2012 09:02 AM
hi, where to buy hayden rear sway bar mounts...how much? thnx
radar54321 05-16-2012 09:06 AM
hi, my 87 911 ,3.2 carrera oil return tubes leak. has anyone experience replacing?
most important question is how to deal with heat exchanger/ exhaust on driver's side?
a porsche mechanic told me it can be done with a special tool without removing exhaust.
has anyone accomplished this...how?
thnx
Joe Bob 05-16-2012 09:12 AM
Hayden? Isn't he the owner of WEVO?
Welcome to Windrush Evolutions - WEVO - Porsche Products
unclebilly 05-16-2012 08:45 PM
Serious? Holy Crap! I think this is the first time this ever happened...
Oh wait, do a search, I think it happened to to somebody else one time. I think they ended up parting out their car...
Seriously, this is common and there are several documented fixes on ths BBs.
eggsandwich 05-25-2024 11:07 PM
I found this problem on my car tonight, and I'm a little worried! Can anyone let me know whether I can still safely drive with this rear sway bar bracket broken?
http://forums.pelicanparts.com/uploa...1716703476.jpg
Bucketlist 05-26-2024 04:04 AM
Just as an alternative solution the PO of my car had replaced the Sway-bar with a Weltmiester 22mm bar. This is mounted with bolt on bushings. I had to replace these once and found old mustang bushings fit.
http://forums.pelicanparts.com/uploa...1716721378.jpg
pmax 05-26-2024 11:04 AM
The pic appears to show it's just the bolted on brackets falling off, not clear what happened.
Unless that other bracket's about to fail as well, do check, a sedate drive to the shop shouldn't be a problem.
Ian Comerford 05-26-2024 11:42 AM
It looks like the bracket has sheared and will mean that the other bracket is taking all of the load, which is then very likely to do the same. It’s safe to drive to your repairer, but that would be all I’d recommend
PeteKz 05-26-2024 02:57 PM
Ian, once the bracket comes loose on one side, the sway bar flops around and there is little or no force on the other side.
Por_sha911 05-26-2024 06:58 PM
Your handling will be different. I would avoid Laguna Seca or Auto-Xing until it is fixed.
