Brake and oil light
Hello:
I am a newbie to this forum. I have a 1983 Porsche 911 convert. that drives great. The brake light (emergency brake light), comes on after a few minutes of driving, and i have noticed lately that the oil warning light also comes on...sometimes around the same time. The oil level seems to be fine. I did some research on here, and i found out that the brake light is due to a faulty switch in many cases. Then I read a post that mentioned that since the oil light comes on around the same time.....then it might be oil sending unit? I will try to disconnect the battery, to see if that will resolve the issues. If not, what do you guys think the likely cause (switch, oil sending unit, other..?)anyway to know for sure? Thanks |
Brake light indicates that the pads are up for changing...(assuming the circuit is functioning properly.......May indicate a low fluid,...I can only speak from MY 89.
Oil pressure light,..another discussion. Could be the sender (change it out)....or it could be be the real deal...(measure oil pressure)...or, possibly, metering (gauge). AGAIN, these commented items are for my expreience with '89 (not '83),..much less a "convert".\\ Sounds like it could be 2 separate issues and should be investigated. Then, again, it could be common,..although I wouldn't know how so without seeing the electricals. When were your pads last changed? How's the oil pressure gauge reacting, per RPM? Good pressures? Maybe the sending unit, in addition. You've a few paths to investigate, for sure. Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Virginia Rocks!
An 83 is different. Welcome, Orginal Poster...post photos. The oil pressure "dummy" light is wired up so that the brake light will come on at the same time. If the pressure (next to the tach) is OK ~1bar per 1K RPM, then the sender (in the back of the engine, near the flywheel) is bad. If the pressure is bad, stop driving.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
The oil pressure is not exactly 1 rpm to 1 bar all the time....sometimes it is, other times its about 2 to 1 or so, depending on acceleration or gear selection.
However, i think that after 5-10 minutes of driving and not with 100% certainty but when the oil pressure goes under 3 or 2 bar , both the emergency brake light and the oil idiot light both seem to come on at the same time..... So is that a symptom of oil pressure warning light that causing both of these lights to come on, or something else? How do i verify for certain if it is a (switch or sender, or something else). |
Virginia Rocks!
That's most likely what it is. That's how it went on my car. It's a $10 part, but a little challenging to swap without at least a partial drop. I'm not sure it can be tested. They call it the idiot light for those that choose not to look at the oil pressure gauge.
