h4 upgrade problems
so I did the h4 upgrade
I installed 40 amp relays on the white and yellow wires coming from the fuse panel to the headlights. 40 amp relays (post 30) I ran new hots into a fuse block used 20 amp fuses (post 85) put good grounds on all relays (post 86) line from original fuse panel (post 87) line to light. Now I am getting a very high pitch squeel from one of the relays and my high beams dont flash or come on. I am lost. |
Sounds like you have something mixed up...
Pull your relays. Identify the contacts and coils with a meter and try it again.. If you can test your relays while they are out, it will probably help you understand what they are doing. At least a bump to the front.... |
The contact numbers are right. Did you mirror them by some chance?
http://forums.pelicanparts.com/uploa...1224659155.jpg |
Relays were all wired fine.
Problem was in the wiring between the switch and the dimmer relay. Thanks everyone. |
| All times are GMT -8. The time now is 07:40 AM. |
