Sonjay's Avatar
Do you know what this is?
I've restored Porsche for 35 years and this is the first time I've ever seen this. They are weights from the inside one left and one right of the front bumber of a 1968 911L as you can see by the pictures they have a 901 parts number and each one weights about 30LBS and they are tuck insdie the roll on the bumper on each side of the bumper mount very strange. What do you think.
Gary Stratton
Stratton Motorsports
(407)421-1911
Old 03-16-2009, 08:17 PM
I've never seen them personally, but I knew that they put lead weights in the front on early cars, and based on your pictures and weights, those are very possibly lead (I know that a plate, about 3/4 inch thick, and 6x10 or so in size is just about 30 pounds).
I'm surprised you've never seen them before. I wonder if shops started removing them soon after they came out.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 03-16-2009, 08:36 PM
Laneco's Avatar
Those, like the cocktail shakers on 60's american convertibles, look like something that should be tossed.
Don't toss... You might not find them again and they are part of a proper restoration of the early cars.
angela
Hello
Old 03-16-2009, 08:54 PM
John W
I just registered so I could reply to this. I'm just learning to turn a wrench but am having fun doing it on my 89 targa. I have read about the history of the 911 and when they first put the engine in the rear they had handling issues from the weight imbalance so the quick fix was to add weight to the front. I forget the year but they corrected it by moving the rear axle back so they could eliminate the front dead weight.
Here's the toy.
I hoping you didn't find out the hard way. Seeing that car in the air, I hope you were expecting the extra weight and had able help while removing the bumper. When I removed mine, the weight of the bumper was quite unexpected and I'm lucky I had good padding on the ground.
John Thompson
Eugene, Oregon
Old 03-17-2009, 07:51 AM
Sultan of Sawzall
rouxroux's Avatar
angela
Spot on Angela...we've got them in our '66 convertible (at all 4 corners)!
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 03-17-2009, 08:03 AM
moneymanager's Avatar
Frere covers this in detail.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 03-17-2009, 08:16 AM
Carmel Skip's Avatar
Not lead but cast iron,factory installed to provide better handling
60 MGA sold
66 912 sold
69 912 sr sold
67S
Old 03-17-2009, 08:19 AM
a.k.a. G-man
Geronimo '74's Avatar
img]http://forums.pelicanparts.com/uploads14/911+11237262069.jpg[/img]
+1
According to what I've heard and read, this is the correct explanation
Not the most elegant solution to improve handling if I may say so.
Old 03-17-2009, 08:29 AM
Fast Corners's Avatar
Gary,
I had these on my '67 911S. They were added by Porsche to correct a high speed instability that is associated with the early model 911's. IIRC, they were 25 lbs each. As there were no spoilers or other devices developed at the time to counteract the aerodynamic lift on the early cars the Factory added the ingots inside the front bumpers in an attempt to keep the front end more firmly planted at high speeds.
On my '67, I removed them for weight savings and ran the car for a short time. I can say from experience that at speeds north of 100 Mph the steering got so light that I sometimes wondered if the front tires were even touching the ground. Understeer in high speed curves was unbelievable. I ended up re-installing them and they do help.
Rhet
FC
'73 911 Track Car
'99 996 Daily Driver
'93 968 Wife's Car
'05 Cayanne S Family Car
Old 03-17-2009, 08:50 AM
