-   -   Paint code request (http://forums.pelicanparts.com/porsche-911-technical-forum/463253-paint-code-request.html)
tomdeg 03-16-2009 01:00 PM
Paint code request
Hello,
I'm trying to find a name for paint code 447-9-3 on a 76 911. Any suggestions?
Thanks,
Tom
Nine9six 03-16-2009 01:21 PM
Did you try a search on "paint codes"?
Thank Tonythetarga...
http://www.paintscratch.com/search.html
Select Porsche in the manufacturer menu and then put in the # and you get your confirmation and a sample color.
Tony G.
86 911 3.2
tomdeg 03-16-2009 01:36 PM
Thanks Tony but I tried paintscratch (and the rest of the web) already and came up with ziltch
KevinP73 03-16-2009 02:06 PM
According to my copy of the red book there is no "447" listed either as a standard color or as a special order color.
tomdeg 03-16-2009 04:36 PM
Here's a photo
http://forums.pelicanparts.com/uploa...1237246589.jpg
KevinP73 03-16-2009 05:36 PM
I see a 443 as a Copper Brown Metallic and a 474 (78-83) as a Rosewood Metallic
KevinP73 03-16-2009 05:44 PM
Could this possibly be a RoW or a grey market car? Maybe that would explain why the number isn't in the book.
S2GART 03-16-2009 06:32 PM
I have the same tag, but mine is in the trunk, on the passenger side, towards the front near the light. I took the 5 digit code to the dealer and they could not find it. My car was bought new in the U.S (Porsche/Audi of Manhattan)
BTW, the word above the code is German for synthetic varnish.
tomdeg 03-17-2009 07:02 AM
No, according to the vin it is a US car. This sticker is also in the jamb. I thought they were all shot with lacquer. http://forums.pelicanparts.com/uploa...1237298434.jpg
tomdeg 03-17-2009 09:11 PM
bump
Jim Williams 03-18-2009 04:45 PM
I did a search on the Glasurit site for 447 and got nothing. I had earlier found the code for my car, 432, a 1974 911, and got a hit. I had to leave off the "-9-3", also on my paint tag, in order to find the paint color. Here is the link:
http://www.glasurit.com/COLOR/COLOR-ONLINE
Then "Search for a formula".
djpateman 03-19-2009 08:57 AM
It is not in any of my lists, so that qualifies it to go into my custom list. It may be a unique color, or just very rare. Getting a COA on the car might be useful, or at least see if PCNA can come up with anything on the paint. Surely for some of these custom colors they would have information needed for repainting. This one is definitely in the browns; the 9 indicates Porsche built, and the 3 is for Herberts paint (that is why you won't get a hit on Glasurit site.)
Jim Williams 03-19-2009 02:42 PM
Note that my paint code also has a 3, but I got a hit on the Glasurit site.
My advice is don't waste your money on a COA. My COA from Porsche says the original paint on my '74 was Silver Metallic, when the paint tag is plainly stamped 432 or Copper Brown Metallic.
djpateman 03-20-2009 07:05 AM
Jim, in many cases of standard or optional colors, the paint could be supplied by several vendors. When you get into the custom colors, that is usually not the case. Without a lot more data I cannot say what colors were supplied exclusively by one supplier. Many colors would not look exactly the same if they came from different suppliers. If your COA is not correct, then have them correct it, that should cost nothing since they made the mistake. If you need help in that, please contact me.
Jim Williams 03-20-2009 04:22 PM
Thanks for the offer of help with PCNA. However, I have emailed them in accordance with the letter I received with the COA, informing them of the errors. One month and no answer. So I called them, and to make a long story short enough to tell here without me getting my knickers in a knot all over again, I was told that if they had made a mistake they would refund my money. Another month, and no reply. They don't appear to know how to correct the errors, nor to be in the least bit interested in making a refund.
I suppose I could have told them what to type in, but that would defeat the purpose of trying to find what their records say. They also had no record of the transmission number.
Needless to say, PCNA is not high on my list of folks I will contact again with any Porsche needs. It appears that if they don't have prospects of selling you a new car, they don't have much of a reason to help you out. But of course, Your Mileage May Vary........
madmmac 03-20-2009 05:34 PM
Can you post a pic of the car? It may help.
Jim Williams 03-20-2009 06:03 PM
Mitch,
Below is a photo of the '74, but it's not going to help regarding the paint color issue. The current paint is not original. At least it's not Copper Brown Metallic OR Silver Metallic. Traces of what I believe was Copper Brown Metallic appear in the engine compartment where the sound deadener has come off; that's the only place where any trace of what might be the original color can be found.
http://forums.pelicanparts.com/uploa...1237597176.jpg
jealxndr 03-22-2009 08:01 AM
Paint Code
Does anyone know what L999 YZ stands for? I can't find this color match either. I was told by Previous owner it was champagne. Who do you contact at Porsche for vehicle history?
jealxndr 03-22-2009 08:06 AM
http://forums.pelicanparts.com/uploa...1237734359.jpg
pete917 04-30-2009 12:45 PM
does anyone know where these is a list of all the colour codes for the 911's over the years?
djpateman 04-30-2009 02:08 PM
Most online lists have a lot of errors. I'm doing research trying to get a comprehensive list from 1965 to 1983 covering the first three styles of paint codes. The are a lot of unidentified custom #s. Also the L999 referenced above basically means it is custom, and good luck determining the actual colour.
KevinP73 04-30-2009 02:30 PM
I've used "Porsche 911 Red Book 1965-1999" by Patrick C. Paternie over the years. It's worked well for me.
pete917 04-30-2009 02:48 PM
Thanks Guys. I was think of compiling a list and making it available on line..... sounds like it might be a bigger task than I thought.
djpateman 04-30-2009 07:25 PM
Lets just say I have more than a year into the project, and I'm not ready to publish yet. I put 20 years into the 914 codes before I was satisfied, and published them. I figure it will be less than a year yet before I'm ready this time.
