JW Apostate
trekkor's Avatar
simple how-to ignition timing
Could someone point me to a thread or give me the steps I need to time my new 2.6 motor.
Built on a '74 7R case.
Webers, no vac advance.
What's the target degree at what rpm?
I'm really close to a great running motor.
Still snorting and popping a bit.
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 03-16-2009, 10:35 PM
Optimal ignition timing depends on many things including:
1) Compression ratio
2) Camshaft profile
3) Fuel octane
4) Maximum outside air temps
Once you have that data, one can offer some constructive suggestions,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-17-2009, 12:44 AM
JW Apostate
trekkor's Avatar
OK.
9.5:1
Solex cams
91 octane pump gas
max air temp 110, usually sub 90, high 80's.
KT
'01 Boxster
Old 03-17-2009, 11:26 AM
An early S distributor and about 5º initial timing will get you in the ballpark. The total advance is about 30º BTDC.
However, to optimize the advance curve for any non-factory spec engine, I'd recommend some chassis dyno time where the operator tracks an optimal advance curve throughout the useable rpm range, then send the distributor to someone like Steve to replicate the mechanical curve with some margin of error for variations in operating condition.
Sherwood
Old 03-17-2009, 11:56 AM
JW Apostate
trekkor's Avatar
I should have full advance by 3500 rpms, right?
KT
'01 Boxster
Old 03-17-2009, 12:08 PM
KT
The S advance curve is all in by around 2500 rpm.
Note: distributor speed = 1/2 engine speed
Sherwood
Old 03-17-2009, 01:13 PM
