Ugh, the smell of burning popcorn
82 911sc. Went to take the kids out for a ride on this nice NJ day, hadnt driven the car in about a month. Get about 1mi down the rode and my daughter starts telling me she smells burning popcorn. Sure enough, turn around, get the car home, open up the engine lid and the lovely smell and smoke engulf the garage.
Smoke seemed to be bellowing from upper right hand corner of the engine. Looking for some ideas on what it could be. Didnt see any new oil leaks, or issues from underneath the car. Took it back out again a little while later, drove it slowly around the neighborhood, everything seemed fine. Took the kids back out, got the car up to speed and more burning popcorn smell. The heat pad is half off already, maybe its that, some mice, bugs, leaves, something internal? |
If you have any history of mice in or around your garage it would be wise to pull the alternator/fan assembly loose to make sure none have taken up residence on top of the motor, that is a quick way to overheat a cylinder or two.
Michael Sans Porsche...for now 2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy 2010 Subaru Forester X Limited - wife's daily driver |
found a nice nest in the hood, took 2 months to get the smell out. now if he found his way into screwing up my engine, that will make me none to happy.
It probably WAS popcorn.... chipmunk's corn cache taken from a local bird feeder...
just my guess. regards, jlex.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
better remove the fan housing and check inside over the cylinders and oil cooler for debris. good way to overheat the engine if the critters packed crap in there, and they do.
Come to think of it, squirrels actually did knock down bird feeder, wife brought it into garage, dropping the food all over the floor. Orville Reddenbacker would not be very happy to have his popcorn flavored with the taste of engine oil.
Will have at it this weekend, maybe i'll move the cat into the garage permanently. |
Yeah, do you want real butter or synthetic???
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
More popcorn, more smoke. Well thought i got rid of the critters about a month ago. Went out for a ride, and more burning popcorn smell,a nd this time lots more smoke.
white smoke pouring from over top of rear passenger tire, and thru the right side of the interior dash vents. oh my. not sure if its rodents or something worse. |
Ae you seeing normal temps?
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Platinum Member
Follow JW's advice.....
Temps were all fine, removed fan housing a few weeks ago and couldnt see a thing back there, and everything seemed to clear up, unless the rodents filled it back up.
could it be any guess guess i could try removing fan housing again, any suggestions on how to keep them out for good. |
![]() Mothballs spread around the engine comp't help a lot to keep them away. Don't store cat food or dog food in the same garage as the car. It attracts the mice. Tape over the exh & intake openings also helps. Use dried mint leaves for the inside of the car front & back. Easy to vac up in the spring & has a nice smell when on that first run of the season. Of course good advice for next winter, a bit late for this. Len
