Gibbs penetrant
Do you guys stateside know if the Gibbs product you are using of the magnesium fan and shroud is available in a non pressurised can ? I emailed the company asking but they never replied. The reason I ask is Iam down in Australia and would like to try it but aerosols are not possible to send via airmail and it seems now that sufrace mail between our two countries no longer exists.
"farking Porsche hero"
Yes. When I got my can of Gibbs I also got a small pump spray bottle.
Rich '66 911 #303872 '07 Cayman '17 Macan '58 Land Rover S2 88" |
AutoBahned
also try Boeing Boe-shield (T9 I think) and "Corrosion Block" products
I have never been convinced that Gibbs is better than those |
ZEP makes a similar product called Rust off or something like that.
'67 911S '69 911S, '70 911ST '73 911T Targa Signal Yellow '78 911SC backdate |
Gibbs is great but so is every other penetrant I have used on Mag. WD40 even works great...
68 911L |
Which one should I use?
I did some searching and here are the home pages of these products, but i have no idea which one to order. Does it even mater? The sites all had really good info. BoeShield: http://www.BoeShield.com/index.htm Gibbs: http://www.roadsters.com/gibbs/#how Zep: http://www.zep.com/products/products.aspx?CatalogMode=1&CategoryID=3&SearchTerm=penetrant Corrosion Block: http://www.nocorrosion.com/cart/showitem.php?pid=1 2 Questions: 1. Anybody with a specific recommendation or problem with any of these products? 2. On the Gibbs site, it showed magnesium wheels that were corroded. Gibbs was sprayed on, then allowed to "soak in" for a few days. A ScothBrite was then used to remove the corrosion. Is this process also recommended for the fan and shroud for our beloved Porsche engines? Greg __________________ 75 US Carrera 03 Cab 2 69 Z11 Camaro Pace Car
